Front Sprocket - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: Fazer 1000/FZ1 corner (https://foc-u.co.uk/mybb/forumdisplay.php?fid=75) +--- Thread: Front Sprocket (/showthread.php?tid=60382) |
Front Sprocket - bigbluebear - 25-09-12 I'm sure there a few out there that have changed the gearing and dropped down a tooth on the front sprocket. Am I right in thinking that the standard is 16 and dropping down will make a significant difference to acceleration, I am aware that the top end speed will be compromised but not sure of how much.....any replies on this subject will be very much appreciated. Re: Front Sprocket - ghostbiker - 25-09-12 I went up 2 on the rear, it did sharpen the acceleration and did not lose any noticeable top end. Well not any top end that I used anyway. On the down side fuel costs went up and tyre wear to. Also be aware that the speedo will be out to unless u use a speedo healer. There is a line of thought that 1 down on front also adds stress and wear to chain where as 3 up on rear is better and the same result. I felt 2 on rear was a better compromise for me. Oh and cruise speed on mway etc is a bit more buzzy. But it is fun
Re: Front Sprocket - JayB - 25-09-12 Tyre wear increased on the rear?! More wheelies? :lol Re: Front Sprocket - dazza - 25-09-12 Hello Bigbluebear, I have played about with front sprockets, both going up 1 and down 1. Really enjoyed going down 1 as you really notice the difference in acceleration and I know this is going to sound infantile but very satisfying blitzing litre sportsbikes with the low down torque avaliable. The speedo does over read but in a way this can help you to keep your speed down. As for affecting the top speed, does that really matter on the roads ? What I was concerned about was putting more miles on the bike due to the over-reading and have gone back to standard for now but if I ever do a track day it will defo be going back on.
Re: Front Sprocket - manuel32 - 25-09-12 Did you have to lter the chain length or is there enough scope to adjust it on the bike? Re: Front Sprocket - dazza - 25-09-12 No, there seemed to be enough adjustment to cope either way.
Re: Front Sprocket - bigbluebear - 26-09-12 Thanks Dazza, to be honest I'm not that bothered about the speedo or the mileage going up. The acceleration is what I'm looking for an improvement on. Re: Front Sprocket - JayB - 27-09-12 Thinking of doing this too, I think every bike I have had I have done, some needed - Aprilia twins and Triumph 955i (18T standard anyone?!) and a carbed R1 had been done previously, pulled in top like my mate's in 4th! :lol Will prob do this once I decide I'm getting a new chain and Sprox. Re: Front Sprocket - Capt - 27-09-12 A genuine Yam FZS600 46 tooth sprocket (5VX-25446-00) is the same carrier fitting as the Gen 1 Fazer 1000. As it uses the same chain there are no noise issues at all using the original front. Makes the dam thing shift off the line & drive out of corners much better however, mainly down to the IVANS full monty, 3 degree advancer, TPS set dynamically. No bogging at all, never checked the top end, who cares anyway. WHAT A BIKE!! Re: Front Sprocket - bigbluebear - 01-10-12 Now fitted with the 15 tooth new front sprocket, new back sprocket and new gold chain.....Bloody Hell....what a difference in acceleration, absolutely brilliant would recommend it. What I did notice was the original sprocket had a rubber mounted noise reduction fitted while the new one has not. This has caused an increase in the noise whilst pulling away......I can live with though with the improvements its made. Re: Front Sprocket - JayB - 01-10-12 (01-10-12, 10:22 AM)bigbluebear link Wrote: Now fitted with the 15 tooth new front sprocket, new back sprocket and new gold chain.....Bloody Hell....what a difference in acceleration, absolutely brilliant would recommend it.Sweet, does it feel OK at motorway speed? I am seriously considering this, they are pretty overgeared as is. Also, did you build up your own kit or source as one..? I am thinking of getting a Gold chain and Renthal or Talon anodised rear sprocket for a bit of eye candy, I am not a fan of aluminium original sprockets, they get so shitty looking quite rapidly in my experience. Re: Front Sprocket - bigbluebear - 01-10-12 Went for JT Sprockets and heavy duty gold chain and got my mechanic to source. I have only had a short burst on the motorway on my way home and didnt really get a chance to fully test as it was chucking it down with rain. Re: Front Sprocket - devilsyam - 01-10-12 its a good mod done it to all the fazers i have owned, cheap mod |
