Speedo tacho plastic covers - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: Fazer 1000/FZ1 corner (https://foc-u.co.uk/mybb/forumdisplay.php?fid=75) +--- Thread: Speedo tacho plastic covers (/showthread.php?tid=60339) |
Speedo tacho plastic covers - JayB - 21-09-12 Guys, can the rev counter cover be removed? Mine appears to have been wiped over with a dirty cloth. I thought it was on the outside but nothing will get the marks off, so it has to be inside? Re: Speedo tacho plastic covers - GrahamB - 21-09-12 The whole front comes off if you remove the clocks from the bike. 3 nuts hold clocks to subframe from memory, 10mm spanner, several phillips head screws hold the face on from the back. About 12? They might have been wiped over with something nasty that has stained the face of them in which case you can polish them using T cut or G-3. Re: Speedo tacho plastic covers - Falcon 269 - 22-09-12 I'd use plastic polish rather than T-Cut.
Re: Speedo tacho plastic covers - GrahamB - 22-09-12 Hello Mike. I didn't know you could get plastic polish! What's it called? G-3 is less harsh but some people don't know of it. Re: Speedo tacho plastic covers - Falcon 269 - 23-09-12 A couple of options for you, Graham ![]() This one is new on me but looks promising. This is the stuff we used for decades in my old job. Re: Speedo tacho plastic covers - JayB - 24-09-12 Hi cheers guys, will have a go at that then, someone must have tried to "clean" them at some point....
