Engine black - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: General (https://foc-u.co.uk/mybb/forumdisplay.php?fid=65) +--- Forum: General (https://foc-u.co.uk/mybb/forumdisplay.php?fid=69) +--- Thread: Engine black (/showthread.php?tid=60288) |
Engine black - CliffRose - 17-09-12 Hi all......can I ask what's the best engine paint to use as some of mine has come off. I know some of you guys have had to re paint your engines. Do I need high temp paint... Cheers. Cliff Re: Engine black - bikerboys - 17-09-12 off my top of my head i fink it was this stuff I used have a look in the fzs600 one of the lads was painting his and tarting it I used the same paint if i find the old post i will put it up there http://www.ebay.co.uk/itm/1-x-250ml-Jet-Black-Engine-Block-Enamel-Petrol-Oil-Resistant-Heat-Paint-Rocker-/290629149663? Re: Engine black - bikerboys - 17-09-12 :rollin it will not let me edit the post :lol any way I have found it now http://www.ebay.co.uk/itm/Engine-Enamel-Heat-Resistant-Paint-Gloss-Black-250-ml-/120965836278?_ that the stuff you need I have used it and still looks good to this day it was recommend by a member on there and here's the old post http://foc-u.co.uk/index.php/topic,1017.0.html adeejaysdelight Re: Winter
Re: Engine black - D4Delta - 17-09-12 Will it do to paint the exhaust pipes as well? Mine are a bit rusty at the front where they come from the cylinders. Re: Engine black - bikerboys - 17-09-12 (17-09-12, 06:13 PM)Old David B link Wrote: Will it do to paint the exhaust pipes as well? Mine are a bit rusty at the front where they come from the cylinders. to be honest no it would not be up to the job that bit it dose get hot a lot hotter then then engine this stuff shud do it http://www.ebay.co.uk/itm/125-ml-VQD-Car-Motorcycle-Exhaust-Paint-Matt-Black-Very-High-Temp-Heat-Resist-/120844826584? just have a look for some hvt black matt or gloss that Resists temperatures of 650[sup]o[/sup]C intermittently, and 450[sup]o[/sup]C continuously. then you will be ok Re: Engine black - manuel32 - 17-09-12 I have painted exausts in the past, it never works, burns off Re: Engine black - Lazarus - 17-09-12 tbqfh - i would say use a spray paint - it give a better finish. its a bit of an arse masking off the areas that u dont want paint on, but the finish is better. Ill dig out the details of the spray I used and post it up. Re: Engine black - Panthor - 17-09-12 Whats the best way to prep the engine? Do u need to take off all the old paint first? Re: Engine black - D4Delta - 17-09-12 Thanks for the advice. David. Re: Engine black - Lazarus - 17-09-12 (17-09-12, 09:55 PM)Panthor link Wrote: Whats the best way to prep the engine? Do u need to take off all the old paint first? i prepped it with wet & dry sandpaper on the bits where I wanted the paint to go - then masked off all the areas where I didnt want it to go Re: Engine black - Lazarus - 17-09-12 this is the one I used http://www.wemoto.com/parts/picture/FE-PJ1HIGHTEMPEXHAUSTPAINT/ Re: Engine black - D4Delta - 18-09-12 Thanks Lazarus. Website says not available at the moment, but will keep my eyes open. David. Re: Engine black - Lazarus - 18-09-12 that link was only to show the paint I used - its available from other places - just do a google search Re: Engine black - alan sherman - 18-09-12 I'm not the only one that has used smoothrite successfully an I? Works a treat. |
