fz6 s1 carb/vacum sync - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: General (https://foc-u.co.uk/mybb/forumdisplay.php?fid=65) +--- Forum: General (https://foc-u.co.uk/mybb/forumdisplay.php?fid=69) +--- Thread: fz6 s1 carb/vacum sync (/showthread.php?tid=60239) |
fz6 s1 carb/vacum sync - ddtwelve - 12-09-12 Just had the carb/vacum sync done on sunday set it at 20 with four bar carbtune just had one that was four levels out and a couple with 2 bars reset ,now it seems to run a bit smoother not as much buzzing around 6-7 thou and i can see through my wing mirrors at 80mph, seems weird feels more powerful [img alt=:eek]http://foc-u.co.uk/Smileys/efocicon/shocked.gif[/img] Re: fz6 s1 carb/vacum sync - Grahamm - 13-09-12 Erm, that's a good trick because the FZ6 is fuel injected...! :pokefun Re: fz6 s1 carb/vacum sync - ddtwelve - 13-09-12 Yep but there is true 4 vacuum hoses underneath the tank which you connect too ,with the tank up you'll see a 2 inch sqaure metal box with numbers 1-4 on it adjustments are made there do not adjust no1 as that's the standard setting adjust all the others to match no 1 then hey Presto ya done ,make sure engine is warm and after each adjustment blip throttle upto 4k leave to settle then check and adjust where necessary
Re: fz6 s1 carb/vacum sync - BBROWN1664 - 13-09-12 You are balancing the engine which is correct but the comment Graham picked up on was the fact you mentioend carbs when your bike doesnt have them :pokefun There is a common problem on the CBF1000 that I am sure would be resolved with a rebalance but the stoooopid foccers at Honda decided that their fuel injection system was intelligent enough to do it automatically and removed the ability to do it as a workshop job. People have tried and ended up buying £1000 worth of new parts to fix it again. Re: fz6 s1 carb/vacum sync - locksmith - 13-09-12 Think you mean balancing the throttle bodies Bob :pokefun Re: fz6 s1 carb/vacum sync - BBROWN1664 - 13-09-12 Thats the one. :thumbup |
