Fuel Tank removal - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: FZS600 Fazer (https://foc-u.co.uk/mybb/forumdisplay.php?fid=78) +--- Thread: Fuel Tank removal (/showthread.php?tid=60210) |
Fuel Tank removal - xlewisbdx - 10-09-12 Hi guys, just wondering if the tank on the FZS600 1998 is vacuum or not. I want to remove the tank to get at the speedo thing under there but i don't want petrol pissing everywhere. Any help greatly appreciated Cheers Lewis Re: Fuel Tank removal - Tiberius Onklevaart - 10-09-12 it should be fairly simple to remove but simpler to just lift. top bolt off, lift a bit and declip the fuel switch. A rod or a bit of wood about a foot and a half long to prop it up and go do your thing. if you want to remove it altogether, turn the tap at the base of it, remove the overflow pipes and do the long bolt at the rear side and take it off. Re: Fuel Tank removal - darrsi - 11-09-12 Speedo thing, or fuel gauge? Under the tank? Re: Fuel Tank removal - xlewisbdx - 11-09-12 I've have been told there is a sender unit under the fuel tank for the speedometer. Re: Fuel Tank removal - Tiberius Onklevaart - 11-09-12 the fuel sender is the one you declip. you won't have to remove tank completely to get at it I should think |
