Wobbling front wheel ! - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: Fazer 1000/FZ1 corner (https://foc-u.co.uk/mybb/forumdisplay.php?fid=75) +--- Thread: Wobbling front wheel ! (/showthread.php?tid=60200) |
Wobbling front wheel ! - Dickydido - 10-09-12 Suggestions please: If I take my hands off the bars the front end wobbles like crazy: also feels a bit unsure at hard acceleration. Possible causes ? Re: Wobbling front wheel ! - Lazarus - 10-09-12 tyre pressure? Had the same issue with mine and got advice that ranged from wheel bearings to stripping down the whole front end. Check the Tyre pressure first and then the front wheel bearings next. Wobbling front wheel ! - trudd - 10-09-12 Do you have a top box or anything heavy on the back seat/rack? Re: Wobbling front wheel ! - Falcon 269 - 10-09-12 Front end wobble, hands-off, decelerating isn't unusual. Going light and floaty on hard acceleration ain't that unusual, either. However, it could be that you need to firm up the rear end.How heavy are you? Re: Wobbling front wheel ! - tiggr2 - 10-09-12 Easy stuff first - have you changed the tires lately? unbalanced wheels or even some tires (my OE ones did this) can cause this, have a look for a clean spot on your wheel rim where a weight might have fallen off also. As said by others addition of luggage can cause it or saggy rear sussies (ooer missis). If non of these, then wheel bearing, head bearings, twisted forks, etc, etc, but tink about thye simple one first.. Re: Wobbling front wheel ! - Dickydido - 10-09-12 thanks folks. Will check pressures. Bike an 05 with only 3000 miles. Had new tyres last year but were not balanced then. No additional luggage and a mere 13 stone rider. Re: Wobbling front wheel ! - Lazarus - 10-09-12 (10-09-12, 02:35 PM)Dickydido link Wrote: No additional luggage and a mere 13 stone rider. Lightweight :rollin
Re: Wobbling front wheel ! - manuel32 - 10-09-12 On my old vfr you could not loose the bars gothey would slap but my new Fazer i found yesterday is steady as a rock, hands off the bars and no problems. Re: Wobbling front wheel ! - 1967fazer - 10-09-12 Mines normally rock solid with my hands off, tho discovered the other weekend when I had packed soft panniers and camping gear strapped to the back, that I got massive wobbles on the front end!!! It does get wibbly when accelerating hard tho. Re: Wobbling front wheel ! - SEPTIKANGEL - 10-09-12 It wobbles with your hands off the bars under acceleration? I'd examine the choke cable then, it's probably wrapped around the idle adjusting screw and is slapping against the top and bottom yoke. If your hands still keep coming off the bars, turn the hotgrips off or try some of those Oxford Handlebar winter muffs. Tricky! Re: Wobbling front wheel ! - unfazed - 18-09-12 Don't take your hands off the bars, problem solved. :rollin Re: Wobbling front wheel ! - DryRob - 19-09-12 could be the road surface or your bar end weights |
