hotgrips problem - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: General (https://foc-u.co.uk/mybb/forumdisplay.php?fid=65) +--- Forum: General (https://foc-u.co.uk/mybb/forumdisplay.php?fid=69) +--- Thread: hotgrips problem (/showthread.php?tid=60178) |
hotgrips problem - ddtwelve - 08-09-12 Just wired up my new/secondhand controller all went wellturn engine on then controller seem to work then lights on controller went off but repressing up button lights back on but flashing then off anyone had this problem or is it knackered :'( Re: hotgrips problem - ghostbiker - 08-09-12 need more revs to up the voltage, try holing the revs at 3k and press the button to turn it on..... or turn it on as riding on a nice stright road. Re: hotgrips problem - ddtwelve - 08-09-12 try it tomoz on my ride to york :lol Re: hotgrips problem - AdieR - 08-09-12 It won't work properly unless your alternator is charging - if your bike is idling, it might not be enough. I get the same with mine (I take it its Oxfords you've got). Re: hotgrips problem - chris.biker - 08-09-12 Have you wired them into the lighting circuit? Re: hotgrips problem - Andy FZS - 09-09-12 Does it work ok with your lights off? If it does then as suggested above it may turn off if the voltage is below a certain level to save the battery from going flat. Andy
Re: hotgrips problem - ddtwelve - 09-09-12 Well 3k reached and the thing worked so happy as Larry :lol Re: hotgrips problem - flesh - 09-09-12 Had this problem loads of times with Oxford grips, especially when wired up via the loom or into an ignition live. I contact Oxford a few years ago and they said that their grips are designed to run directly via the battery and not into the bikes electrics. Since then I have always wired them up this way without a problem. Do need to give it some revs though
Re: hotgrips problem - MadDogMcQ - 10-09-12 Oxford Hot Grips are designed to be connected directly to the battery and if you leave them on by mistake, they will switch themselves off before the battery is flattened - IN THEORY! I tried it on mine a couple of years ago (on a different bike) and they didn't switch off until the battery was so low that it only just started the bike! So when I fitted a pair to my Fazer, I put them through an ignition-controlled supply (using a relay). If your grips won't work with the engine not running, it suggests to me that your batteryt voltage is already low! Especially if it's the same when the engine is running. Put a voltmeter across your battery and let us know what the voltages are....
Re: hotgrips problem - Grahamm - 10-09-12 (10-09-12, 08:34 AM)MadDogMcQ link Wrote: Oxford Hot Grips are designed to be connected directly to the battery and if you leave them on by mistake, they will switch themselves off before the battery is flattened - IN THEORY! It would be a bit more faff, but couldn't you connect them via a relay linked to the igntion circuit such that they'll only be activated when the bike is switched on? Re: hotgrips problem - MadDogMcQ - 10-09-12 (10-09-12, 08:34 AM)MadDogMcQ link Wrote: ....So when I fitted a pair to my Fazer, I put them through an ignition-controlled supply (using a relay).... Re: hotgrips problem - Grahamm - 10-09-12 :o Re: hotgrips problem - VNA - 10-09-12 Quote:It would be a bit more faff, but couldn't you connect them via a relay linked to the igntion circuit such that they'll only be activated when the bike is switched on? Just use a switched live off straight off the fuse box. See the write up by pointer2null on the old forum - http://fazerowners.yuku.com/topic/5650/HOWTO-Fit-your-heated-grips-PICS-BACK#.UE5KNNU6PIs I added some pics that show how to pick up the switched live. These are of my 2004 gen1 thou, but I'm guessing all the fuse boxes are probably similar if not the same. I did find my original controller needed some revs when the bike was cold to stay on. The second controller I've fitted, after the first failed after a few years use, powers up on a cold tickover no probs. I personally wouldn't wire them off anything else. It's the correct way to do it, butchering wires and no overloading any circuit. And it's easy. Re: hotgrips problem - Buzz - 11-09-12 Get one of these, makes it very easy to grab an existing switched 12V straight from the fusebox. The bottom slot is for the fuse you've just taken out of the fusebox, the top one is for the live wire you're feeding to the grips. As the heated grips have an inline 5A fuse just use a 10A in the top slow of the fuse tap. No soldering, no mess and about 1 mins work. http://j.mp/RH1xmD |
