Vibration Through the Left Footpeg - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: Fazer 1000/FZ1 corner (https://foc-u.co.uk/mybb/forumdisplay.php?fid=75) +--- Thread: Vibration Through the Left Footpeg (/showthread.php?tid=60054) |
Vibration Through the Left Footpeg - bigbluebear - 28-08-12 Wondering if anyone can shed a light on vibration from my left footpeg. In fact I am experiencing a some vibrations through the handle bars as well. It is pretty annoying as these vibrations is causing nuts to come loose and I have recently lost my tax disc holder and now checking all nuts and bolts fater each ride out Re: Vibration Through the Left Footpeg - bigbluebear - 28-08-12 I have been reading the post by MadDogMcQ and I have also been recently Ivanised which may be causing the issues. The mechanic who did the work assured me he balanced the carbs and followed the instructions although he did tell me he didn't clip the springs. He said that would be pretty hard to get them the exact same length and couldn't really see the benefit although the coments on here say otherwise. Re: Vibration Through the Left Footpeg - Rusty - 28-08-12 I have it too, but can't find where it's from. :\ Re: Vibration Through the Left Footpeg - Falcon 269 - 28-08-12 Installed correctly, Ivan's kits don't cause vibration. More often, the motor is smoother after being 'Ivanised'. I'd be looking at chassis-related causes, also wheel balance, chain alignment and security of engine and exhaust mounts. Re: Vibration Through the Left Footpeg - Rusty - 28-08-12 Mike.... your only a genius that's all. I've recently had two new tyres fitted and wheels balanced, after which I got the left footrest vibes. Since reading your post I've just taken a look at my silencer which had been knocked and repositioned -presumably during the rear wheel refitting. It was standing away from the bike somewhat more than before. I've pushed it back into it's original spot and from the short run up the street and back it appears the vibes have diminished. Well by 'eck! Re: Vibration Through the Left Footpeg - MEM62 - 28-08-12 I'm with Mike, my bike has been silky smooth since he worked his magic on it. Suspension next for me Mike, as you have done more mods than most to your bike over the years what do you recommend. (Not looking to do the R1 fork conversion though) Re: Vibration Through the Left Footpeg - bigbluebear - 28-08-12 I also has two new tryes fitted, Pirelli Diablo Strada's which were balanced. The vibration didn't start until after being Ivanised so I will check the chain etc. If they the Ivans kit was fitted incorrectly is it easy enough to do it again as drilling has taken place etc Re: Vibration Through the Left Footpeg - bigbluebear - 28-08-12 Mike...do you ever come to Glasgow to do work Re: Vibration Through the Left Footpeg - sd1 - 28-08-12 Might be well of the mark here, but my fzs600s centre stand rubber was missing and it was just touching the left foot peg, and other side was touching exhaust, that gave some pretty weird vibrations through the bike, mainly the left peg. Cheers Re: Vibration Through the Left Footpeg - Falcon 269 - 29-08-12 (28-08-12, 03:14 PM)bigbluebear link Wrote: I also has two new tryes fitted, Pirelli Diablo Strada's which were balanced. The vibration didn't start until after being Ivanised so I will check the chain etc. Just 'cos the tyres were balanced doesn't mean that they're still balanced. Weights fall off, tha' knows. ![]() As for Ivan's installation, if the holes have been drilled incorrectly, most times you're stuffed. The exception would be if the pilot circuit bypass holes haven't been completely drilled through. In this case, a few more turns with the drill bit would be enough to rectify the situation. I have worked in Glasgow/Scotland a couple of times but the majority of my bookings come from much further south. Driving distances are a big factor in planning my trips, as you'll appreciate.
Re: Vibration Through the Left Footpeg - manuel32 - 29-08-12 At the speed everything spins,wheels,sprockets,chains on fast bikes there is no room for an out of balance part,or rattle of a part, have you ever looked down at the ground when doing 140 mph,,shit, things are spinning :eek Re: Vibration Through the Left Footpeg - bigbluebear - 30-08-12 (29-08-12, 05:23 AM)Falcon 269 link Wrote: [quote author=bigbluebear link=topic=4406.msg36724#msg36724 date=1346163290] Just 'cos the tyres were balanced doesn't mean that they're still balanced. Weights fall off, tha' knows. As for Ivan's installation, if the holes have been drilled incorrectly, most times you're stuffed. The exception would be if the pilot circuit bypass holes haven't been completely drilled through. In this case, a few more turns with the drill bit would be enough to rectify the situation. I have worked in Glasgow/Scotland a couple of times but the majority of my bookings come from much further south. Driving distances are a big factor in planning my trips, as you'll appreciate. [/quote] Checked all the engine mounts bolts chain exhaust etc no loose bits. I did detect a slight movement in the left peg so maybe thats what the cause is. I have the slip on version and not the full monty and the bike has been dyno tested at 135bhp so I can probably rule out the pilot holes not been drilled through properly as I would assume this would affect the output. The only thing I thnk the mechanic didnt do was clip the springs so I may do that myself if it will make a big difference to the throttle response Thanks for the advice Re: Vibration Through the Left Footpeg - PaulSmith - 30-08-12 Another cause of the type of vibration you are taking about includes incorrect tension on your Exup valve control cables. |
