just swapped engine over and oil light won't turn off! - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: FZS600 Fazer (https://foc-u.co.uk/mybb/forumdisplay.php?fid=78) +--- Thread: just swapped engine over and oil light won't turn off! (/showthread.php?tid=59979) |
just swapped engine over and oil light won't turn off! - Kinggy - 22-08-12 hi guys, just changed my engine over on my 2001 fazer, everything runs sweet as a nut but the only thing is, is that the oil light will not turn off! theres plenty of oil in there as topped up to the specified amount... could this be an engine management problem or something else? any help on trying to.get this light off would be muchly appreciated Re: just swapped engine over and oil light won't turn off! - richfzs - 22-08-12 faulty sensor? Re: just swapped engine over and oil light won't turn off! - peteski - 22-08-12 It won't be engine management, the fzs isn't that advanced It just a simple sender and warning bulb. Have you checked for a faulty sender unit.
Re: just swapped engine over and oil light won't turn off! - red98 - 22-08-12 swap it over with the one on your old engineĀ
Re: just swapped engine over and oil light won't turn off! - red98 - 22-08-12 or take the top cover off and make sure the oil is getting to the top of the engineĀ
Re: just swapped engine over and oil light won't turn off! - AdieR - 23-08-12 Before you replace the sensor, check in case you've trapped or damaged any wiring first - it does happen. |
