rattle from clutch in neutral - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: FZS600 Fazer (https://foc-u.co.uk/mybb/forumdisplay.php?fid=78) +--- Thread: rattle from clutch in neutral (/showthread.php?tid=59897) |
rattle from clutch in neutral - philshaq - 16-08-12 Hi guys I got back from a bit of a run out this eve and noticed when I knocked it into neutral and let the lever out there was a rattle. Pull the lever back in and it stops. It doesn't seem to do it when gears Srebrenica engaged... Is it anything serious? Please say it isn't! Re: rattle from clutch in neutral - CRH - 16-08-12 it isnt ......most of them do it?....make sure your idles set right and live with it!!...
Re: rattle from clutch in neutral - keno - 16-08-12 Its the clutch basket,don't worry its a noisy fecker but normal for the faz..
Re: rattle from clutch in neutral - philshaq - 16-08-12 Thanks for the advice guys, didn't want it to be terminal so shortly after finding the fun bit above 8000rpm!! Phil Re: rattle from clutch in neutral - ade the blade - 16-08-12 no no no.............don`t believe them all. ya ride is on the point of catastrophic failure as i type this. that rattle is the detonator / delayed timer that Mr Yamaha builds into all fazers. Red98`s went off and look what he`s left with............a totally blown off head :rollin :rollin :rollin :rollin :rollin :rollin :rollin :rollin :rollin only kidding matey, nowt to lose sleep over ! |
