Sub Cowl - Silver Tech - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: Fazer 1000/FZ1 corner (https://foc-u.co.uk/mybb/forumdisplay.php?fid=75) +--- Thread: Sub Cowl - Silver Tech (/showthread.php?tid=59881) |
Sub Cowl - Silver Tech - MEM62 - 15-08-12 Does anyone know if these are available anywhere? The part number is 5LV-W0714-30-00 Re: Sub Cowl - Silver Tech - karlo - 15-08-12 Do you mean a bellypan? http://www.ebay.co.uk/itm/New-Unfitted-Black-FZS1000-Fazer-Bellypan-belly-pan-subcowling-FZS-1000-/140824976641?pt=UK_Motorcycle_Parts&hash=item20c9d29d01 http://www.ebay.co.uk/itm/2004-YAMAHA-FZS1000-FAZER-BELLYPAN-FZ1-FZS-1000-STREETFIGHTER-PROJECT-/221100832351?pt=UK_Motorcycle_Parts&hash=item337aa2f65f Re: Sub Cowl - Silver Tech - MEM62 - 15-08-12 Yep, that's the one. I was hoping to pick one up in Silver Tech but thanks for spotting the black one - I might have a bid on that.
Re: Sub Cowl - Silver Tech - b1k3rdude - 16-08-12 (15-08-12, 04:22 PM)karlo link Wrote:Do you mean a bellypan? Something to be aware of, I bought one of the 'pattern" black ones from cactus composites and of the two lower halves one side was thicker than the other. I spent ages bending the connecting brackets into slight s-shapes to accombate the extra thickness. Had I know this before getting it sprayed I would have sent back the offending side. And the bottom of the second one has been smashed, possible beyond repair. Re: Sub Cowl - Silver Tech - pitternator - 17-08-12 who would buy a cowl which is broken in half !! Re: Sub Cowl - Silver Tech - karlo - 17-08-12 Me if it was cheap enough and I wanted one. Re: Sub Cowl - Silver Tech - MEM62 - 17-08-12 b1k3rdude Thanks for the heads up on that. I really wanted the original Yamaha accessory but, having looked for a while, I have not been able to source one. I might still go for that if it is cheap enough because then I won't mind some fiddling around to fit it. Re: Sub Cowl - Silver Tech - b1k3rdude - 18-08-12 (17-08-12, 11:06 AM)MEM62 link Wrote:Thanks for the heads up on that.Just contact the company (Cactus Composites) and tell them to make sure that the two bottom halves are the same thickness, otherwise you'll have to do what I did. Also when bidding you may want to factor in a few costs - belly pan cost £90 (should have stuck to the £75 budget), £150 getting it colour matched and powder coating on the brackets was £10. But when you consider the original Yamaha item new cost over £200 I don't feel to bad. |
