Carb balancing question - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: FZS600 Fazer (https://foc-u.co.uk/mybb/forumdisplay.php?fid=78) +--- Thread: Carb balancing question (/showthread.php?tid=59880) |
Carb balancing question - DryRob - 15-08-12 I'm going to be balancing my carbs soon but am a bit confused about something. The Haynes manual and workshop manual both tell me to adjust the idle speed the adjuster but neither mention the throttle position sensor (TPS) in pointer2nulls guide. The question is, do I adjust both, one or neither? Re: Carb balancing question - ozpom - 15-08-12 Do both. I always follow pointer2null's guide (or one very like it) and it always makes a big difference :thumbup The Haynes manual probably has the TPS adjustment in a different section :rolleyes Re: Carb balancing question - Andy FZS - 15-08-12 pointer2null's guide ? :\ Andy Re: Carb balancing question - richfzs - 15-08-12 Try here Re: Carb balancing question - DryRob - 20-08-12 I've done it now, t'was easier than expected. Does the TPS need setting back to 0 RPM once I'm done? There seems to be a small delay between reving the throttle and the engine picking up now. Re: Carb balancing question - richfzs - 20-08-12 Nope, should read 5k.... if it started at 0k, then was wrong before you started... |
