Carb to Head Rubbers - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: FZS600 Fazer (https://foc-u.co.uk/mybb/forumdisplay.php?fid=78) +--- Thread: Carb to Head Rubbers (/showthread.php?tid=59835) |
Carb to Head Rubbers - bigsteve - 12-08-12 Hi I imagine this subject has been on here before but i will ask it any way My good ladies FZS 600 needs Carb to Head Rubbers replacing ( 51 Plate 9500 Miles ) Are there any pros's or con's between after market and genuine Yamaha rubbers other than price :eek ??????? Any advice will be greatfully received CHEERS Re: Carb to Head Rubbers - red98 - 12-08-12 replaced mine a while back now.the pattern parts i bought were as good as origanal,side by side it was hard to tell them apart,these rubbers are very thick,mine were cracked badly and were like it for years before i finally got round to changing them,but once off the bike i could see the cracks were not all the way through....by a long way...if you have the same problem and the cracks are not that bad i would`nt bover changing them. i think i still have the old ones in the garage,i see if i can find them tommorow and post a piccy [size=78%] [/size]
Re: Carb to Head Rubbers - bigsteve - 12-08-12 think one on out side is through as get bubbles when u put liquid over cracks :'( but have put silicone over them for time being Re: Carb to Head Rubbers - Tiberius Onklevaart - 12-08-12 The new ones will likely crack as well, had you not wrote that there's bubbles coming out then i would say leave them but since you know there's a breach then fair enough, just don't panic when the new ones start looking like they've had someone attack them with a sharp hatchet Re: Carb to Head Rubbers - red98 - 13-08-12 ok...sounds as if you need new ones.....i will see if i can find out where i bought mine and how much they were....pretty sure somewhere near £75...will let you know
Re: Carb to Head Rubbers - red98 - 13-08-12 had a rummage in the shed tonight and found the rubbers the cracks have closed up now they are not on the bike and you cant see them in the pictures :\ i bought them from WWW.MAD4BIKES.CO.UK and paid £78.98 inc p+p.....hope this helps
