just replaced my'zorst :) when to check the bolts ? - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: FZS600 Fazer (https://foc-u.co.uk/mybb/forumdisplay.php?fid=78) +--- Thread: just replaced my'zorst :) when to check the bolts ? (/showthread.php?tid=59746) |
just replaced my'zorst :) when to check the bolts ? - Enceladus - 04-08-12 i have just replaced my standard downpipes for s/s ones and end can for a scorpion ![]() whilst having a brew afterwards, i realised that i ought to check the tightness of the downpipe bolts on the engine after it has been running for a bit. what would you do ? go for a quick ride (10-15 mins) then let it cool down and check ? thanks p.s. if you have done this yourself how did you get at the 1st bolt for the 2nd cylinder on the right if looking from the front ? was a right sod to get at! Re: just replaced my'zorst :) when to check the bolts ? - darrsi - 04-08-12 Last time i changed the gaskets on my headers i checked the bolts every couple of days for a few weeks as they seemed to slacken off for some reason before eventually settling down, i'd imagine it's a hot and cold thing. Can't say i had any problems with the bolts, just used an extension bar and all was good, just make sure they're all torqued equally. Re: just replaced my'zorst :) when to check the bolts ? - Enceladus - 05-08-12 thanks ![]() can't see the recommended torque settings for these bolts. any idea what they are Re: just replaced my'zorst :) when to check the bolts ? - darrsi - 05-08-12 Torque settings Downpipe assembly Nuts 10 Nm Rear bolt 20 Nm Re: just replaced my'zorst :) when to check the bolts ? - Enceladus - 05-08-12 thanks ![]() must be going blind! couldn't see it for looking! |
