clutch knackered????? - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: Fazer 1000/FZ1 corner (https://foc-u.co.uk/mybb/forumdisplay.php?fid=75) +--- Thread: clutch knackered????? (/showthread.php?tid=59654) |
clutch knackered????? - bluefaze - 26-07-12 clutch adjusted, everything fine, just biting where i want it, 10 minutes later lever full in to bar and she's pulling forward, rather quickly. not good in traffic, or anywhere really. sure i read about this but can't find it. please can some one help
Re: clutch knackered????? - AdieR - 26-07-12 You say 10 minutes in the problem starts - my first thought is it's heat related; have you the right oil, and when was it last changed? Heavy oil can cause the plates to stick together. Have you tried re-adjusting the clutch? Re: clutch knackered????? - red98 - 27-07-12 stretched,worn out cable not adjusted correctly...........easy and cheap to replaceĀ
Re: clutch knackered????? - greeny - 27-07-12 Is it a new cable? I replaced mine with a cheap one and the same thing happened. Went straight to dealer and brought a genuine cable. Much better. Hope this helps. Peter |
