clutch lever problem on gen1 - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: Fazer 1000/FZ1 corner (https://foc-u.co.uk/mybb/forumdisplay.php?fid=75) +--- Thread: clutch lever problem on gen1 (/showthread.php?tid=59645) |
clutch lever problem on gen1 - fazer6868 - 25-07-12 Hi, Can anybody answer this one please? I bought a hong kong originated coloured clutch lever, fitted it and it appears very loose and wobbly as if it is about to drop off. i have checked the bolt and it is tight. it is almost as if something is missing! also gear changing is quite rough as if the clutch is not working properly. the cable is ok as it is new. any ideas please? thanks Re: clutch lever problem on gen1 - Tmation - 25-07-12 Don't buy shit made in China :lol Seriously though it sound like the pivot point is loose and needs a spacer or shim, now refer to my first comment. Re: clutch lever problem on gen1 - ghostbiker - 25-07-12 The one I got from bike-it came with a shim insert to fatten up the bolt as it passes through. The China ones I have now had the right replacement bolt for it in the pack. So didn't need a shim. Re: clutch lever problem on gen1 - Falcon 269 - 26-07-12 You transferred the pivot bush from the original lever to the new one, yes?
Re: clutch lever problem on gen1 - ghostbiker - 26-07-12 (26-07-12, 05:01 AM)Falcon 269 link Wrote: You transferred the pivot bush from the original lever to the new one, yes? There is that falcon fella again, useing the real words as the rest of us strugle with made up ones like shims and bits to fatten up the bolt lol :lol Re: clutch lever problem on gen1 - Falcon 269 - 26-07-12 What, you saying you don't like bush ... ?
