Carb balancing - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: FZS600 Fazer (https://foc-u.co.uk/mybb/forumdisplay.php?fid=78) +--- Thread: Carb balancing (/showthread.php?tid=59608) |
Carb balancing - Jamieg285 - 23-07-12 Simple question - Carbtune or 4x Gauges? Or does it make little difference? Re: Carb balancing - edc - 23-07-12 Only done it the once - with a morgan carbtune. And it was pain free (ish) other than finding the screws. Can recommend. Carb balancing - cable tie - 23-07-12 Yep I can recommend the Morgan's carb tune, I too was a newbie to balancing my carbs 1st time I'd say took me 1hr to get it right now I can do it in about 15-20 mins I still use a very small pencil torch to see the screws as there buggers to see. Re: Carb balancing - red98 - 23-07-12 i use four gauges.....before i start i calibrate them by connecting to the same carb in turn and take note of the reading then adjust my final reading....it is possible too adjust them but very fiddily......get good results
Re: Carb balancing - Andy FZS - 23-07-12 Used both gauges and carbtune over the years both work ok. I have a carbtune now and the hardest thing is finding the adjusting screws. Andy Re: Carb balancing - HarryHornby - 24-07-12 I've done this a couple of times and I've always found it an easy job, with a Morgan carbtune. My only question is, the guide on this site shows to balance them at idle, adjust the screws, give a little rest and take the reading at idle. But, when I then hold the revs up, say about 5k (riding revs) the carb tune is all over the place, so should we also be balancing at higher revs or is balancing at idle totally correct? Carb balancing - cable tie - 24-07-12 You do it at idle, have a look on you tube there plenty DIY on there and I found one chap doing a fazer Re: Carb balancing - Buzz - 24-07-12 There should be some kind of Carbtune timeshare scheme....I'd happily give a fiver to use one for an hour every 6,000 miles. North London anyone?? :b Re: Carb balancing - Jamieg285 - 24-07-12 Looks like there's not much in it then. Is the Carbtune a digital display, or is it liquid filled tubes? I've not been able to tell from the pics/videos I've seen. Re: Carb balancing - Buzz - 24-07-12 Here's a Fazer 600 being tuned motorcycle carburetor balancing- Carbtune Re: Carb balancing - Jamieg285 - 24-07-12 (24-07-12, 11:37 AM)Buzz link Wrote: There should be some kind of Carbtune timeshare scheme....I'd happily give a fiver to use one for an hour every 6,000 miles. Not sure I'd want to do a timeshare, but for £10 you can come to mine and use this and any other tools required to do the job. Might even throw in a cuppa! Carb balancing - cable tie - 24-07-12 (24-07-12, 12:49 PM)Jamieg285 link Wrote: Is the Carbtune a digital display, or is it liquid filled tubes? I've not been able to tell from the pics/videos I've seen. It's neither Jamie, they are stainless rods with a graph on the background to set up so that all the rods align within the same markings, very easy to do you even get a idiot proof manual. Re: Carb balancing - Andy FZS - 24-07-12 Hmmm not sure it's an idiot proof manual I've heard of people trying to use them without fitting the inline restrictor.very erratic readings I understand...... Andy Re: Carb balancing - richfzs - 15-08-12 (24-07-12, 11:12 PM)Andy FZS link Wrote: Hmmm not sure it's an idiot proof manual As soon as you invent something idiot proof, they just invent a bigger idiot. |
