Jittery at low revs - Printable Version
+--- Thread: Jittery at low revs (/showthread.php?tid=59464)
Pages: 1 2 3
Jittery at low revs - darrsi - 12-07-12
I've noticed recently that my bike has been what i can only describe as 'jittery' between 2000-2500rpm.
Once i go over 2500rpm it's fine, picks up well, with no other issues or flat spots.
The more i think about it, it's probably been doing it for a while but as it's been gradual i've not taken too much notice of it, but now it's quite obvious.
It feels almost like i'm in the wrong gear, but i've tried different things and it's still there between those rev. ranges.
Any ideas? I'm sure it's not a difficult one if it rings a bell to anyone, but it's not something i've personally encountered before?
Re: Jittery at low revs - chunk166 - 12-07-12
I had a similar problem with mine at low revs,turned out to be the plug caps,you might just need to trim a little of the HT leads??
http://foc-u.co.uk/index.php/topic,3648.0.html
hope this can help you?
Ray
Re: Jittery at low revs - AdieR - 12-07-12
Is it constant, or does it only happen at particular times (eg cold / hot / wet weather)?
When was it last serviced?
First thing I'd look at is spark plugs / HT leads and replace them if necessary (the plugs will have tell-tale signs by colour / appearance).
Re: Jittery at low revs - Dead Eye - 12-07-12
Just my two cents but it could it be that the carbs need balancing? Mine is a little rough below 2.5k revs and im sure its the carbs, just haven't bothered to do anything about it yet as id like to do it myself but its expensive to get the correct tool
Re: Jittery at low revs - darrsi - 12-07-12
Weather at the moment is all over the place but i don't think it's made any difference, i was in rain AGAIN on the way home from work tonight but it's been doing it in sunshine as well.
I do my own servicing generally.
It's not missing a beat or anything, it's just kind of of jerky. It seems to idle quite happily as well.
I've already thought about carb balancing and was wondering if that would be suggested.
Chunk166, did you trim the other end of the HT leads at all, or renew them at all, or just change the plug caps?
I just trimmed the plug cap ends about 5mm & put on the new caps,been running really good even in the bloody rain,but i would say it started after a down pour but still done it in the dry!!!
Ray
I presume they were just the old push/screw in type?
I'm just looking at the online manual but can't see any reference to the HT leads, ideally i'd prefer to change them as well just in case there's a weak spot in them? I was just curious if they were push/screw fitted the other end as well? I know some can be crimped........and i've no doubt they'll be in a bugger of a tight space as well.  :rolleyes
It's hacking it down with rain where i am, otherwise i'd go and have a look.
I need to find where to get those caps from on the quick as well, from a shop, as i'd like to change them this weekend if possible?
Re: Jittery at low revs - red98 - 12-07-12
ht leads are sealed to the coils,if you need to replace them its new coils time (two on the fazer) the ends do go hard after a while so trimming the ends is a great tip,look at the plugs and check colour and condition and replace if need be,balancing carbs will give you an instant inprovement if they hav`nt been done for a while...if that lot dos`nt work try cleaning the carbs  Wink .....let us know how you get on  Smile
as red98 has said,they are sealed at the coil so not an option to trim that end! your probably looking at £20 for the 4 plug caps
Re: Jittery at low revs - Andy FZS - 12-07-12
Mine was rough under 3k revs and felt as if I was in too high a gear, so I balanced the carbs and now it will plod along at 30mph in 6th gear without any bother.
Andy Smile
Just checked, i had a full carb overhaul at the beginning of last year at PDQ tune up mechanics, when i also had my new end can put on, and as i only really use the bike for work these days that would only mean around 6000 miles at a guess?
I've fortunately got a Hein Gericke a mile up the road from me, and i've just seen that they sell the NGK caps for £4.35 each according to their website, so i can change them at the weekend now  Big Grin
Hopefully i'll be lucky and it'll do the job, if not i'll address the carbs again i s'pose!
New caps won't hurt anyway, seeing as riding conditions seem to be permanently shite in this country!  :'(
Fingers crossed you'll get it sorted soon  Big Grin Big Grin Big Grin
Yeah, cheers for the help lads, much appreciated, i'll let you know how i get on  Smile
Re: Jittery at low revs - darrsi - 13-07-12
Had to get plug caps from a bike shop near my work, only £3 each, bargain  Smile
Re: Jittery at low revs - SORTED - darrsi - 16-07-12
UPDATE: Well i must admit i have been pleasantly surprised, i had the HT leads trimmed and plug caps changed to the NGK ones and lo and behold the problem seems to have been fixed!!
I tried different gears in the offending 2000-2500rpm range and all the 'jittering' seems to have gone, and the engine actually sounds and feels a bit smoother as well.
Happy days, and thanks again for the tip, and input.  Smile
Re: Jittery at low revs - Andy FZS - 16-07-12
Which plug caps did you get straight or angled? Do you know the part No? I ask as I think I may need some.
Cheers
Andy Smile
Re: Jittery at low revs - darrsi - 17-07-12
NGK SD05F, the straight ones, they worked out cheaper in the shop than Flebay eventually.
Use the old protective rubbers at the bottom of the plugs that should be on the old ones.
It's a cheap way to start if you have a similar issue, although i'm sure cropping the end of the HT leads plays just as much a part!.  Wink
Re: Jittery at low revs - darrsi - 02-08-12
Worth having a look at this post i found regarding this problem as it hasn't actually gone away like i had first thought!!
At least i've got some shiny new plug caps now anyway  Big Grin
http://www.fzrarchives.com/ipb/index.php?s=2dcae0a7b7721ee4488932b5125ec678&showtopic=56747&st=0&p=473232&#entry473232
Re: Jittery at low revs - renegaderacer - 02-08-12
I'm not sure if this has any relevance as it was on a car but my old Impreza had exactly the same problem and I changed the coils (not cheap for 4 Impreza coils!) and, voila, problem cured!  Wink
I also had the same probelm on my race bike but that turned out to be a split HT lead and monsoon conditions at Snetterton!  :lol
Giles
I'm open to any suggestions at the moment!!
For the record, the plugs are absolutely fine, i put Iridium one's in about 8 months ago and the colour of them was spot on, in fact they didn't really even need a clean but i brushed them all up and gapped them anyway.
