DL 650 hand guards - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: Fazer 1000/FZ1 corner (https://foc-u.co.uk/mybb/forumdisplay.php?fid=75) +--- Thread: DL 650 hand guards (/showthread.php?tid=59441) |
DL 650 hand guards - ghostbiker - 10-07-12 Just ordered myself a set of the DL 650 handguards i know a few of you have used. Couldnt seem to find a guide to fitting them but often mentioned is needing to modify them a bit. Just so i know what im going to need when they arrive can anyone shed a little more light on it? or will it be one of those things that smack you in the face like a brick its so obvious when you see it lol Re: DL 650 hand guards - tomlinscote - 10-07-12 I had to fabricate little aluminium extensions to mine because they fouled the levers but someone else on this forum posted pics of a really neat job, just can't rember who it was, DOH! They do work well though, in summer almost too well my hands now get hot!!! Maybe I should get some summer gloves!! Re: DL 650 hand guards - kebab19 - 11-07-12 It'll be obvious when you set about fitting 'em, and nothing major to worry about. What bars are fitted - may cause slight screen fouling on the LHS. Mine does, and I remove them just before every MoT Re: DL 650 hand guards - ghostbiker - 11-07-12 Renthal 758's with the fuzzy mirror mod. Though im off today to see if i can find anywhere with some 658's in stock and change them over today as im day off. trouble is cant seem to find anywhere local with them in stock ![]() Re: DL 650 hand guards - fazer69 - 11-07-12 Ive done pictures of mine on here somewhere, they need a bit of tirmming where they bolt on & the bar end of the guards need opened up a bit with a drimmel, for a good fit i finnished off with a heat gun, iam not to handy with spanners & it took meb 30 mins a side, if i can find my pics ill repost. Re: DL 650 hand guards - ghostbiker - 11-07-12 No prob, they arrived this morning so i had a go at fitting them. It needed the hole opened up a little on the right hand side and on the left i trimmed it up to fit over the clutch switch. other than that it was a simple bolt on. not to keen on the bolts supplied with the kit (ok i know they are ment for the DL650 lol ) but they aint pretty. the fzs 1000 ones are a little short to get away with useing them. will most likely keep an eye open for something better. they do foul a lot before i get to full lock, this might be mostly down to having the fuzzy mod on the mirrors. bike is compleatly ridable but is a little restricted when moving it around tight spots. the 658's might make a diff when i finaly get some. |
