mounting gps - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: Fazer 1000/FZ1 corner (https://foc-u.co.uk/mybb/forumdisplay.php?fid=75) +--- Thread: mounting gps (/showthread.php?tid=59406) |
mounting gps - FuZzBoM - 07-07-12 Hi all, i have a Garmin Zumo 220 and have mounted it with the supplied RAM mount kit. i am no happy with it because it looks untidy. How do you peeps have yours mounted? to give some background i have a set of renthal bars fitted with the brace bar. i would ideally like to mount it on the brace bar or behind the clocks but open to suggestions. thanks, Re: mounting gps - Davidjw - 07-07-12 I have the same bar set up as you and have my zumo 550 mounted in the middle on the tank side of the brace works fine but then I dont ride along stairing at it :rolleyes Re: mounting gps - Noj - 07-07-12 I used a SW Motech, took ages to arrive, however it is has an anti vibration mounting. Not sure its the best or it will suit your requirements. Very tidy and tuff. http://www.motohaus.com/acatalog/SW_Motech_Yamaha_GPS_Mounts.html Re: mounting gps - Dave 1625 - 09-07-12 I welded an 8mm nut to the handlebars then had them powder coated black. When i want the sat nav on I simply fit the rubber bal in place. When not using sat nav all you see is a mushroom headed bolt where the rubber mount would sit. looks really neat. I hated the bolt on bracket supplied with my 550 and have tried loads of ways to tidy it up. Re: mounting gps - karlo - 09-07-12 ![]() http://www.buybits.com/Product/14227/Alternative-To-Ram-b-367u-Ultimate-Addons-M8-Handlebar-Clamp-Mount-sku-14227.aspx ![]() http://www.buybits.com/Product/3222/Ram-b-201-a-Short-Double-Socket-Arm-sku-3222.aspx ![]() http://www.buybits.com/Product/9373/Sw-motech-Navigation-Ram-And-Universal-Mount-For-Garmin-Zumo-Cpa-00-424-114-sku-9373.aspx Re: mounting gps - FuZzBoM - 09-07-12 Cheers for the suggestions guys, Karlo -i had seen that setup but cannot bolt the ball in due to the brace bar from the renthals being in The way. Dave 1625 - i like this idea but not having a welder or the ability to use it limits me. also not sure i could weld to alloy renthal bars lol. Noj - I really like the idea of those. seen one on my mates BMW and looks really nice. could you take a picture? again with the bars but not sure it will go round the brace bit. Re: mounting gps - karlo - 10-07-12 http://www.pro-bolt.com/motorcycle/yamaha/fzs1000-fazer-01-05/yoke-nut-centre-of-yoke-plain-drilled/aluminium-top-yoke-nut-50-drilled-for-breather-black.html#.T_vH9X1mQrc ![]() http://www.buybits.com/Product/3730/Ram-1-Ball-With-14-Stud-Ram-b-237-sku-3730.aspx ![]() http://www.buybits.com/Product/4692/Ram-1-Ball-With-14-20-Female-Thread-Ram-b-337-sku-4692.aspx Re: mounting gps - MadDogMcQ - 10-07-12 I drilled a hole in the top yoke and inserted a RamBallMount as seen in the image below. Then used a short Double-Socket-Arm. Mine's a TomTom, but same difference. Re: mounting gps - FuZzBoM - 10-07-12 all sorted ordered one of these. http://www.triumph-online.co.uk/sw-motech-handlebar-gps-pda-mount-for-78-22mm-bars-gps00308100-1820-p.asp(don't worry i didn't buy it from that site lol) all fitted and i am really pleased with it. |
