New Clutch Case Bearings - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: Fazer 1000/FZ1 corner (https://foc-u.co.uk/mybb/forumdisplay.php?fid=75) +--- Thread: New Clutch Case Bearings (/showthread.php?tid=59392) |
New Clutch Case Bearings - gel - 06-07-12 I am doing some work on the olg girl (Fazer) and I am replacing the clutch casing with a new one I got off ebay. I need to know where I can get the oil seal and top bearing where the clutch actuator rod goes through the casing, also need the lower bearing inside the clutch case. I have checked WEMOTO but know joy, are they only available from Yamaha? I think there was a link that Devilsyam put up for a company that did bearings but I cannot find it. Re: New Clutch Case Bearings - karlo - 06-07-12 http://foc-u.co.uk/index.php/topic,13.msg30476.html Re: New Clutch Case Bearings - gel - 06-07-12 Right, contacted the company and as I did not have any bearing numbers then they were unable to help, so I rang my local yam dealer and have now got all the bearing circlips and washers comming. All sorted thanks. |
