FITTED SATNAV MOUNT TONIGHT - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: General (https://foc-u.co.uk/mybb/forumdisplay.php?fid=65) +--- Forum: General (https://foc-u.co.uk/mybb/forumdisplay.php?fid=69) +--- Thread: FITTED SATNAV MOUNT TONIGHT (/showthread.php?tid=59157) |
FITTED SATNAV MOUNT TONIGHT - MadDogMcQ - 18-06-12 Fitted my SatNav mount tonight. Simply drilled a hole in the yoke and fitted the ramball mount shown below. With the SatNav fitted, 0-20mph is obscured by the device, but there's a true speedo reading on the TomTom anyway. Re: FITTED SATNAV MOUNT TONIGHT - SEPTIKANGEL - 18-06-12 Looks allright McQ, my Zumo 550 fits with the ram mount u-clamped to the bars in nearly the same position, but it covers even more of the speedo. Tend to read the Sat Nav speed more anyway. I only use the sat nav when I'm touring which means I use a tank bag too. My Sat Nav's okay for a tank bag in situ - you happy the Tom will clear a bag okay? Re: FITTED SATNAV MOUNT TONIGHT - MadDogMcQ - 18-06-12 I've had a TomTom V1, V2 and now the V3. I've also had a Zumo 550. The early TTR's were a major pain in the butt because of a cradle problem which TomTom denied existed, but they seem to have sorted it eventually! Whilst I prefer the Garmin hardware, I have to admit that IMHO the best software award goes to TomTom. As for Luggage whilst touring, I've got a big 50Ltr Ventura Aero something or other. On other bikes I've had the Bagster Tank Covers and their "Design" tank bag. I do like those and may well get another. Tom Re: FITTED SATNAV MOUNT TONIGHT - Wilko - 20-06-12 I used the bar mount, where you clamp it to the handlebars. I put it centrally on the bars, and it looked okay, had to go around the mount to get to the keys, but no major drama. Only thing I found was that it was too low without obscuring the clocks, and as such I would have to physically move my head to look at the screen. I have now positioned it so that the arm etc comes up behind the clocks and the sat nav actaully sits above the clocks. This has only been possible after buying a bubble type screen to give the extra room. It now saves me physically moving my head to see it, just a downward glance now gives me full vision of the screen and the clocks. Will try and get a pick soon :-) Re: FITTED SATNAV MOUNT TONIGHT - Bizbauer - 24-03-13 Wilko I know it's a long time since this post but how'd you get on with getting pics of your GPS mount behind the clocks? That sounds like what I'm trying to achieve but need a visual to see how it'll work. And did you use any extra hardware on top of the supplied kit? Re: FITTED SATNAV MOUNT TONIGHT - limax2 - 25-03-13 (24-03-13, 01:10 PM)Bizbauer link Wrote: Wilko I know it's a long time since this post but how'd you get on with getting pics of your GPS mount behind the clocks? That sounds like what I'm trying to achieve but need a visual to see how it'll work. And did you use any extra hardware on top of the supplied kit?Not from Wilko but this is how I fitted a satnav above the clocks on a FZS600 box eye with a double bubble screen. [smg id=716 type=preview align=center caption="Satnav mount FZS600 Mk1"][smg id=717 type=preview align=center caption="Satnav bracket"] The satnav case, from Ebay, is a water proof one with a swivel mount on the back that comes with a handle bar mounting bracket. It takes a normal car type satnav, which is much cheaper than a water proof bike specific sat nav. I discarded the handle bar mounting and fitted a 5mm bolt through the tube in the photo and assembled the swivel mount to that. The tube is 16mm dia x 18s.w.g. and bolted to "L" shaped brackets that pick up the mirror mounting studs. (I have the longer Mk2 mirrors fitted which I think may have slightly longer studs than the standard mirrors). The tube has aluminium plugs in each end and tapped 5mm for bolting to the "L" brackets. |
