Used to be Hints n Tips - advice needed on fitting a hard drive..... - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: General (https://foc-u.co.uk/mybb/forumdisplay.php?fid=65) +--- Forum: General (https://foc-u.co.uk/mybb/forumdisplay.php?fid=69) +--- Thread: Used to be Hints n Tips - advice needed on fitting a hard drive..... (/showthread.php?tid=59091) |
Used to be Hints n Tips - advice needed on fitting a hard drive..... - badger - 13-06-12 Not sure where to put this post, admin feel free to move. I am looking to fit an extra hard drive into my home PC, running vista, and i would like the extra drive to act as extra storage for photos videos, music etc. I have had a look on the internet and picked up some advice but further advice on pitfalls what to look out for etc would be greatly appreciated. thanks badger Re: Used to be Hints n Tips - advice needed on fitting a hard drive..... - MadDogMcQ - 13-06-12 It's fairly straight forward, but can i suggest that you consider a portable USB Hard Drive to store your photos and such? MUCH more practical and easy to move around (literally). Re: Used to be Hints n Tips - advice needed on fitting a hard drive..... - MadDogMcQ - 13-06-12 http://www.google.co.uk/products/catalog?hl=en&cp=14&gs_id=d&xhr=t&q=portable+usb+hard+drive&safe=off&qscrl=1&nord=1&rlz=1T4GGLL_en-GBGB372GB372&bav=on.2,or.r_gc.r_pw.r_qf.,cf.osb&ion=1&biw=1920&bih=953&wrapid=tljp1339621912661024&um=1&ie=UTF-8&tbm=shop&cid=4131508716993729235&sa=X&ei=6gHZT-KfBqnC0QW51LWfBA&sqi=2&ved=0CNABEPMCMAM Re: Used to be Hints n Tips - advice needed on fitting a hard drive..... - Grahamm - 13-06-12 If your system can handle SATA, I'd consider getting an OCZ Solid State Drive, installing your OS onto that and then turning your whole existing drive over to storage. It'll also give you faster boot times
Re: Used to be Hints n Tips - advice needed on fitting a hard drive..... - Buzz - 14-06-12 2TB drive in Curry's for £90...bargain. Microsoft also do a very good "sync" tool which mirrors folders on your PC and External drive, perfect for backing up photos/music etc. Get it here Re: Used to be Hints n Tips - advice needed on fitting a hard drive..... - MadDogMcQ - 14-06-12 And why not dump that nasty Vista and move to Win7 while you're at it? Re: Used to be Hints n Tips - advice needed on fitting a hard drive..... - Lawrence - 14-06-12 (13-06-12, 11:56 PM)Grahamm link Wrote: If your system can handle SATA, I'd consider getting an OCZ Solid State Drive, installing your OS onto that and then turning your whole existing drive over to storage.Much faster than a traditional hard disk, but would personally go for Crucial M4. Had lots of OCZ Vertex 2 drives (which I realise are old now) and had lots of failures and incompatibilities with various machines. M4s have been goos as gold. Re: Used to be Hints n Tips - advice needed on fitting a hard drive..... - badger - 14-06-12 Thanks for all the tips and advice. The PC is a few years old now but running ok for what i need from it. I just needed some more cheap storage space to keep me going until i'm ready to replace the pc completely. had also seen this one: http://www.currys.co.uk/gbuk/seagate-freeagent-goflex-ultra-portable-hard-drive-320gb-06824073-pdt.html?intcmpid=display~RR~Computing+Accessories~06824073 Re: Used to be Hints n Tips - advice needed on fitting a hard drive..... - Grahamm - 14-06-12 (14-06-12, 11:54 AM)Lawrence link Wrote: Much faster than a traditional hard disk, but would personally go for Crucial M4. Had lots of OCZ Vertex 2 drives (which I realise are old now) and had lots of failures and incompatibilities with various machines. I looked into this carefully, the series 3 drives appear to have had the bugs sorted out. The only annoying thing is that I found the motherboard I bought only supported SATA 2, not SATA 3 so it's not as fast on booting as it could be
Re: Used to be Hints n Tips - advice needed on fitting a hard drive..... - goldfazer - 14-06-12 Don't go solid state - I did, it's great but needs a lot of techy fiddling to work properly. and not THAT much faster sadly. Re: Used to be Hints n Tips - advice needed on fitting a hard drive..... - Grahamm - 14-06-12 (14-06-12, 02:06 PM)goldfazer link Wrote: Don't go solid state - I did, it's great but needs a lot of techy fiddling to work properly. and not THAT much faster sadly. Err, plug in the SATA drive, check the BIOS recognises it, use it like any other HDD. No problem. Re: Used to be Hints n Tips - advice needed on fitting a hard drive..... - goldfazer - 14-06-12 Err, nope. Well maybe. But if it works reliably, it WILL need some tweaks to get it running at a decent speed, otherwise it will be dog slow. But I guess if you haven't run the tests/diagnostics cos you didn't think they were needed, you wouldn't know that
Re: Used to be Hints n Tips - advice needed on fitting a hard drive..... - Grahamm - 15-06-12 There's a difference between "working properly" and playing around with settings to (possibly) get faster performance which may, in itself, have drawbacks eg write-caching which is fine until you get a power glitch as it's half-way through writing. You can also switch to AHCI (if it's not already set up), but you have to be confident with playing around with the Registry and even then not all drives show a noticable improvement. But I'm sure you already knew that. Re: Used to be Hints n Tips - advice needed on fitting a hard drive..... - goldfazer - 15-06-12 If it's not optimised, there ain't any point in having it - you're wasting money! 'But I'm sure you already knew that.' Yes. But I do IT for a living. Badger asked for basic advice which implies he's not that familiar with the workings of a PC. Let's not get into a 'My PC is bigger than your's'. Having had an optimised SDD for about a year, I probably wouldn't bother again unless they were cheap (got this one half price, but still more than a HDD which was working fine anyway), and mine gets a lot of use. Re: Used to be Hints n Tips - advice needed on fitting a hard drive..... - badger - 15-06-12 (15-06-12, 09:00 AM)goldfazer link Wrote: If it's not optimised, there ain't any point in having it - you're wasting money! Goldfazer - yup my PC knowledge is limited, thats why I asked.i am competent enough to install an additional hard drive with a little bit of instruction. I didn't want to start WW3, but just ask if there were any pitfalls to look out for? My PC is 5 years old but still runs and performs OK and is adequate for what i use it for, I have nearly filled my hard drive and want some extra cheapish storage until i'm ready for a new pc / laptop. I dont really want to spend £80ish for a 1TB HD so looked at putting in an internal drive for between 20 40 quid. Badger Re: Used to be Hints n Tips - advice needed on fitting a hard drive..... - goldfazer - 15-06-12 Just adding an extra HDD is just a plug it in and maybe visit the BIOS/Setup page so it finds the new drive. You'll probably need to format it too (I would anyway, choose FAT32) from within Windoze. It's almost certainly a SATA drive, but you'd need to check (different cables 'n' stuff!). Re: Used to be Hints n Tips - advice needed on fitting a hard drive..... - badger - 15-06-12 Nice one, thank you :thumbup |
