Creaking front suspension - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: Fazer 1000/FZ1 corner (https://foc-u.co.uk/mybb/forumdisplay.php?fid=75) +--- Thread: Creaking front suspension (/showthread.php?tid=59060) |
Creaking front suspension - bigfootpete - 10-06-12 When I turn the handlebars my front suspension makes a creaking noise that seems to be getting worse, anyone come across it before? Lack of lube? Re: Creaking front suspension - CRH - 10-06-12 sounds like your head bearings need a spot a grease???? :rolleyes Re: Creaking front suspension - bigfootpete - 10-06-12 Well, it's definitely due for a service - hopefully that's all the problem is... Thx! Re: Creaking front suspension - bludclot - 10-06-12 this could be something as simple as a part of the loom or a control cable sheath rubbing against one of the leg tops. some simple further investigations with a piece of cloth slipped in each of the touching areas in turn might well reveal a culprit...? Re: Creaking front suspension - bigfootpete - 08-08-12 Update - turns out it was the front brake - right pad was worn right down, didn't even notice a problem braking :-) Expensive service though - £250, think I also need to re-lube the exup as it doesn't look like he touched it... 3 hours labour... Re: Creaking front suspension - alan09 - 08-08-12 (08-08-12, 08:08 PM)bigfootpete link Wrote: Expensive service though - £250,...silly question, but what excactly do you get in a service for £250 that you cant do yourself. Re: Creaking front suspension - bigfootpete - 08-08-12 Pffft, I know bugger all about engines, and I have massive hands that are shit at getting into tight spaces. I'd rather leave that up to someone who has the space, time and knowledge to not stuff it up. Although saying that he probably just replaced the oil and filter, brake pad, checked the plugs and adjusted the chain and lubed everything up... I don't know what else he may have checked. Re: Creaking front suspension - alan09 - 08-08-12 (08-08-12, 09:31 PM)bigfootpete link Wrote: Pffft, I know bugger all about engines, and I have massive hands that are shit at getting into tight spaces. I'd rather leave that up to someone who has the space, time and knowledgeand your £250...if all they do is oil & filter change, check & or replace brake pads + new plugs, i'm really neanderthal when it comes to mechanics but all of these jobs are/seem quite straight forward. |
