fender extender fitting - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: General (https://foc-u.co.uk/mybb/forumdisplay.php?fid=65) +--- Forum: General (https://foc-u.co.uk/mybb/forumdisplay.php?fid=69) +--- Thread: fender extender fitting (/showthread.php?tid=59036) |
fender extender fitting - ddtwelve - 08-06-12 hi ive a carbon fibre fender extender and was wondering what size screws are needed to fit :eek Re: fender extender fitting - slappy - 08-06-12 The right size! The ones on my plastic one are about 4mm diameter by about 10mm long and are just self tapping screws. Re: fender extender fitting - robby boy - 08-06-12 I fitted mine with plastic number plate bolts don't look to bad. Re: fender extender fitting - Fazerider - 09-06-12 I glued mine on with silicone sealant... no screws needed.
Re: fender extender fitting - Rusty - 09-06-12 Don't use just two screws. My bike developed terrible vibration at some speeds/revs and it was traced to a fenda extenda that had come unglued and was flapping about in the airstream. That in turn caused vibes to run up the bars. There was only one screw either side holding it on and the glue in the middle had let go. I put in another two screws to secure it but they were'nt 10mm long, more like 5mm. I worried that with tyre flex the tip of a longer screw might catch the tyre, and at 10mm the point could be felt protruding. Re: fender extender fitting - ade the blade - 09-06-12 pop rivet the darling on. nice neat jobby !! Re: fender extender fitting - MEM62 - 09-06-12 Mine is fitted using just the adhesive pads that came with it. They held the thing so tight I didn't feel the need to use the screws that came with it. Re: fender extender fitting - phil on a fazer - 11-06-12 (09-06-12, 09:20 AM)Fazerider link Wrote: I glued mine on with silicone sealant... no screws needed. i used some Evo glue, then Silicone sealant to stop the water getting into the glue. rock solid. Re: fender extender fitting - bludclot - 13-06-12 tiger seal. used extensively in the car trade and sticks like the proverbial. have stuck a couple of mine on with no problems at all. Re: fender extender fitting - ddtwelve - 13-06-12 Well fitted last night with heavy duty double sided tape, 3 stainless screws and silicone sealant around the edges just to be sure :lol |
