Daylight Only MOT????? - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: General (https://foc-u.co.uk/mybb/forumdisplay.php?fid=65) +--- Forum: General (https://foc-u.co.uk/mybb/forumdisplay.php?fid=69) +--- Thread: Daylight Only MOT????? (/showthread.php?tid=59025) |
Daylight Only MOT????? - Minty - 07-06-12 Just looking at this on evil bay, for general introduction to bike mechanics for my lad and noticed the geezer states it has a daylight only MOT. Never heard of it, has anyone else? http://www.ebay.co.uk/itm/Kawasaki-KDX200-Road-legal-Enduro?item=160817097276&cmd=ViewItem&_trksid=p5197.m7&_trkparms=algo%3DLVI%26itu%3DUCI%26otn%3D5%26po%3DLVI%26ps%3D63%26clkid%3D8971147863665868260 Re: Daylight Only MOT????? - locksmith - 07-06-12 Yeah, common for enduro bikes with no lights or brake lights. Strictly speaking it's a normal mot with an advisory not use after dusk I think. Mines the same. Re: Daylight Only MOT????? - imax - 07-06-12 A ‘daytime MOT’ is the popular rather than official term used for a Ministry of Transport vehicle test which confirms your motorcycle is legally roadworthy for use only in daylight and conditions of clear visibility. If your bike meets the test criteria you will be issued with a normal MOT certificate but with an advisory note (a VT32) which confirms the daytime/ visibility restriction which applies. If you have a daytime MOT you may not legally use your bike on the public highway outside of daylight hours or at times of seriously reduced visibility. To qualify for a daytime MOT your bike must “have neither front nor rear position lamps, or have such lamps permanently disconnected, painted over or masked.” This applies to headlamps, position lamps and indicators. The situation with stop lamps is significantly more complicated. Machines do not need to have a stop lamp fitted if they cannot exceed 25mph, were first used before 1[sup]st[/sup] January 1936 or were first used before 1[sup]st[/sup] April 1986 and do not exceed 50cc. Those first used before 1[sup]st[/sup] April 1986 must have a stop lamp that operates from at least one brake control and those used on or after that date must have a stop lamp operated from both brakes. There is an added if not widespread complication for bikes first used from 1[sup]st[/sup] April 1986 which were approved with a stop lamp activated by one control. There were very few of these and test inspectors are instructed to fail a bike only if they are certain the stop lamp was designed to be operated by both brake controls and isn’t. Hope this helps
Re: Daylight Only MOT????? - locksmith - 08-06-12 Confusion reigns here doesn't it ![]() I recently took my enduro for an mot. It has been mot'd before by the previous owner(s). It has a headlight, a permenently on tail light and a brake light operated by the rear brake only. I arrived with the front and rear lights taped over and tape around the light switch. The tester told me to untape the rear one as I didn't need it. The thing I did overlook was a rear reflector which he overlooked as well because it probably fell off on my way home :lol Re: Daylight Only MOT????? - caretaker - 08-06-12 my trials bike has no lights at all, and no stop light either. just a number plate and a battery powered horn. it was bought like this but its not on the road at the mo. will be putting it on the road soonish and will keep you posted. Re: Daylight Only MOT????? - sadlonelygit - 08-06-12 both my husky and ktm are 'daylight only' MOT's. both have the lights fitted asa i get home. both are tested at the same garage, by the same tester. one passed without a reflector, one failed for no reflector :rolleyes go figure! Re: Daylight Only MOT????? - J. Laplante - 23-06-13 (07-06-12, 07:12 PM)locksmith link Wrote: Yeah, common for enduro bikes with no lights or brake lights. Strictly speaking it's a normal mot with an advisory not use after dusk I think. Your are experienced and you did said what i intended to say.. |
