Possible issue or just paranoid? - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: FZS600 Fazer (https://foc-u.co.uk/mybb/forumdisplay.php?fid=78) +--- Thread: Possible issue or just paranoid? (/showthread.php?tid=59006) |
Possible issue or just paranoid? - Fazer Jake - 06-06-12 On startup my downpipes 3 & 4 seem to heat up ALOT faster than 1 & 2 i can't hear any blowing of any sort and i've only recently changed the plugs. Is this normal or would it suggest carbs balanced? Bike runs find and seems to jump 100-200rpm on idle. Re: Possible issue or just paranoid? - darrsi - 06-06-12 There's no blowing AND the bike runs fine ??? I reckon you've just answered your own question........ :lol Re: Possible issue or just paranoid? - Fazer Jake - 06-06-12 (06-06-12, 07:08 PM)darrsi link Wrote: There's no blowing AND the bike runs fine ??? Well fine ish, i get no where near the MPG some lads get on here, i average 47mpg and powers jerky sometimes at lower rpm Re: Possible issue or just paranoid? - darrsi - 06-06-12 Do you have an aftermarket exhaust or end can, they can make them a bit jumpy at lower revs, mine does it and i've got 'new' down pipes and an SP Engineering Moto GP end can? It certainly breathes much better when i give it a bit of welly though with the end can. I've never really bothered about MPG, if the gauge says half full i fill it up, sorted.
Re: Possible issue or just paranoid? - Fazer Jake - 06-06-12 True Darsi, ive got after market GP style zorst, after market downpipes, K & N. would this suggest it likes the nuts revved off it? :rolleyes Re: Possible issue or just paranoid? - darrsi - 06-06-12 Personally it sounds okay to me, and YES i believe they do appreciate the odd thrashing every now and then.......especially with a tank full of Shell V Power on board :evil Re: Possible issue or just paranoid? - limax2 - 06-06-12 It sounds to me like the carbs could do with balancing. I presume you are talking about how hot the pipes are getting with the engine at tickover. In which case it would indicate that 3 and 4 are doing most of the work with 1 and 2 not contributing their share. Carb balancing will probably sort it and you will probably notice an improvement in low speed responce/smoothness as well. Re: Possible issue or just paranoid? - Andy FZS - 06-06-12 Pre carb balance less than 2,5k revs was very rough but after balancing it will pull from tick over in the lower gears and sit at 30mph in 6th gear. I've also just set my pilot air screws (well 3 of them can't get to the 4th) and now the engine is super smooth at all engine speeds. Re: Possible issue or just paranoid? - darrsi - 07-06-12 My carbs were stripped and refitted by PDQ when i had my new can put on, and it doesn't feel any different even now. It runs sweet........sits at 1300 rock solid, and that was done ages ago.......still a bit quirky at very low speeds though. |
