Help, Can't put myself on the map. - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: General (https://foc-u.co.uk/mybb/forumdisplay.php?fid=65) +--- Forum: General (https://foc-u.co.uk/mybb/forumdisplay.php?fid=69) +--- Thread: Help, Can't put myself on the map. (/showthread.php?tid=59000) |
Help, Can't put myself on the map. - thesagaciousman - 06-06-12 Hi, New to the forum. I want to put myself of the map, but can't seem to get it to work. Can someone please help. Cheers S Re: Help, Can't put myself on the map. - GringoRojo - 06-06-12 welcome to the madhouse Saggy (you didn't expect us to call you the whole thing did you?) try refreshing with the F5 key, and if that doesn't work try Alt F4. Re: Help, Can't put myself on the map. - thesagaciousman - 15-06-12 Haha. Alt f4 :rolleyes . I will try again. Could be iPad related I suppose. That didn't occur to me at the time. :\ ? Re: Help, Can't put myself on the map. - Phil TK - 15-06-12 Looking at the map I see that I'm located apprx two miles out to sea. Re: Help, Can't put myself on the map. - dickturpin - 15-06-12 How far out to sea should you be? Re: Help, Can't put myself on the map. - Ian-man - 15-06-12 . click on member map on top of forum home screen . under map click on message that asks if you want to add yourself. you then get transferred to your profile, map section . find your location however close you want it to your actual location, (I use the nearest pub) . click on change profile button at bottom right when your happy and that's it. Re: Help, Can't put myself on the map. - thesagaciousman - 28-06-12 Thanks for the replies. I'll give it another go. |
