Advice please! - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: General (https://foc-u.co.uk/mybb/forumdisplay.php?fid=65) +--- Forum: General (https://foc-u.co.uk/mybb/forumdisplay.php?fid=69) +--- Thread: Advice please! (/showthread.php?tid=58970) |
Advice please! - Dave48 - 04-06-12 On removing bellypan on my FZS 1000 I discovered radial cracks in the plastic surrounding the rear mounting holes. :'( Front ones have rubber inserts with steel bush so these ok. Rear ones have no anti-vibration bushes/collars-is this correct? Any recommendations re "plastic welding/repair? Re: Advice please! - CRH - 04-06-12 i had similar problem with the fairing on my fjr ...the btm rear mounts on that were doing exactly the same!!! what i did was trap the bolt between 2 rubber tap washers !! just have to enlarge holes a bit?? job done!!
Re: Advice please! - chris.biker - 05-06-12 The hugger on my bike had the rear mounting hole wear a way, I repaired it by Evo Sticking a patch of plastic on the inside out of sight. It has held, if this is any help. |
