Temperamental tail brake light... - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: FZS600 Fazer (https://foc-u.co.uk/mybb/forumdisplay.php?fid=78) +--- Thread: Temperamental tail brake light... (/showthread.php?tid=58960) |
Temperamental tail brake light... - Buzz - 03-06-12 Afternoon... I checked my rear brake light this morning and something's wrong. The lever gives a "click" as if the microswitch is opening but the tail light doesn't immediately turn on, it's only when I squeeze a good 2cm past the "click" does it come to life. What's more worrying is that it doesn't come at all in 1 out of 4 squeezes :eek I'm guessing the light is meant to come on at the "click"? The rear pedal works fine BTW and activates the light straight away. Microswitch problems? I might take it out and give it a clean when it stops raining on Tuesday. Re: Temperamental tail brake light... - Bracechenko - 03-06-12 The microswitch will be corroded and needs replacement. I know because mine just failed an MOT and no amount of WD40 helped. The mechanism still worked but when I removed and split open the insides were completely corroded and oxidised beyond repair. The good news is that a replacement cost less than a fiver from Ebay, is easy as pie to fit (1 screw holds the switch in place) and it did the trick perfectly :thumbup Re: Temperamental tail brake light... - bikemad62 - 03-06-12 I would go with the replacement plan. I got an led rear light and had the same problem changed it and job done. |
