Access To Spark Plugs (FZS Fazer 1000 04) - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: Fazer 1000/FZ1 corner (https://foc-u.co.uk/mybb/forumdisplay.php?fid=75) +--- Thread: Access To Spark Plugs (FZS Fazer 1000 04) (/showthread.php?tid=58955) |
Access To Spark Plugs (FZS Fazer 1000 04) - Fuzzygoth - 03-06-12 I am trying to change my spark plugs today, I can easily access the ones either side of the engine but the ones in the middle of the engine block look a little more tricky to get to. What's the best way to get them out (I have the toolkit). I'd hope removing the tank would give me easier access but on doing it it didn't look quite that easy. Cheers Fuzzygoth Re: Access To Spark Plugs (FZS Fazer 1000 04) - tomlinscote - 03-06-12 The supplied spark plug spanner is indeed one of the easiest ways to get them out, I have done this on mine (-04 too) as the tank is fairly easy to remove I took it off and there was little problem removing the plugs. The hardest part is not cross threading them when putting them back in, it maybe worth trimming a little of the ends of the plug leads too, and make sure the plug caps really are fitted back tightly, one of mine wasn't and it gave me rough running once I washed the bike!! Cheers P Re: Access To Spark Plugs (FZS Fazer 1000 04) - Fuzzygoth - 03-06-12 Cheers dude I am less worried about removing the tank as I've done it before but its my first spark plug replacement and the midle two look well tricky. Cheers Fuzzy Re: Access To Spark Plugs (FZS Fazer 1000 04) - bash62 - 03-06-12 ye i agree the best spark plug spanner is the yam one .easy enough just a tad fiddly cheers bash Re: Access To Spark Plugs (FZS Fazer 1000 04) - PaulSmith - 06-06-12 A rachet with various extenders and universal joints will help. Remember to be very gentle as anything you have to force, you are doing wrong. Re: Access To Spark Plugs (FZS Fazer 1000 04) - SEPTIKANGEL - 06-06-12 (06-06-12, 12:12 PM)PaulSmith link Wrote: A rachet with various extenders and universal joints will help. Remember to be very gentle as anything you have to force, you are doing wrong.No Paul, as Bash said, the Yam ones's best, 'specially when reinstalling. There's a better 'feel' from the lightweight Yam plug spanner that you don't get with other stuff. It's not the easiest of jobs, but if my chubby fingers and big hands can do it, anyone can. I do recall contorting my arm, upside down, sideways, inside out and everywhichwaybutloose to unscrew and reinstall, but it is possible, just make sure you frequently use the words, Fuc*, Bas**** and other expetives, 'cos it helps! :lol Re: Access To Spark Plugs (FZS Fazer 1000 04) - samsung - 06-06-12 Get shut of the AIS,changing plugs is then a doddle .
Re: Access To Spark Plugs (FZS Fazer 1000 04) - dekker555 - 06-06-12 Here's how I dumped my AIS,system, plugs a doddle now. http://www.cartestsoftware.com/fz1/airinductionsystemremoval.html |
