changing air filter - easy ? - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: FZS600 Fazer (https://foc-u.co.uk/mybb/forumdisplay.php?fid=78) +--- Thread: changing air filter - easy ? (/showthread.php?tid=58933) |
changing air filter - easy ? - Enceladus - 01-06-12 planning on changing the oil, filter and putting in a mag drain plug this weekend, and that got me thinking (yes, i know that's dangerous !) i would doubt that the air filter has been changed recently and could probably do with being replaced. is it an easy thing to replace ? don't mind a bit of work, but would prefer not to have to remove the tank ifi can help it. thanks ![]() Re: changing air filter - easy ? - Andy FZS - 01-06-12 It's not difficult................once you've removed the tank Re: changing air filter - easy ? - Dead Eye - 02-06-12 Air filter is easy enough to replace, easier than the oil filter in my opinion... or at least that was the case with my adventures... It's located underneath the fuel tank, just in front of the battery
Re: changing air filter - easy ? - fishwibbler - 16-06-12 Yep, if memory serves, undo one bolt, prop up the tank carefully on a piece of wood then do the necessary. If you have a carb Fazer, I hope you have a K&N filter to liberate the midrange? Good luck amigo, fish. Re: changing air filter - easy ? - darrsi - 16-06-12 NO propping, take tank off, then procede :eek Re: changing air filter - easy ? - red98 - 16-06-12 yea tank off jobbie....be carefull not to trap the two breather pipes when re-fitting.and to make the job a little easier wait until the tanks nearly empty
Re: changing air filter - easy ? - jason1 - 16-06-12 Tank OFF , easy job Re: changing air filter - easy ? - Oxygen - 16-06-12 Easy and the manual is in the forum somewhere. Re: changing air filter - easy ? - Enceladus - 16-06-12 thanks for the replies ![]() was hoping not to have to remove the tank, but looks like i have little option. k&n on order ![]() |
