Cage trouble - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: General (https://foc-u.co.uk/mybb/forumdisplay.php?fid=65) +--- Forum: General (https://foc-u.co.uk/mybb/forumdisplay.php?fid=69) +--- Thread: Cage trouble (/showthread.php?tid=58898) |
Cage trouble - pete786.u - 31-05-12 :car Parked up at the local Garden Centre yesterday, went to start the car and couldn`t release the steering lock or turn the ignition key. Called the AA and the guy had to butcher the ignition barrel trying to sort it out. Ended up with a hot wire system to keep me going. The outcome is that I need a new ignition barrel and probably a new steering column :'( Imobilisor still works as does all the other electrics except the clock and outdoor thermostat.(fuse ?) May end up fitting a switch for the ignition and a push button for the starter motor and forget the steering lock and new ignition barrel. Re: Cage trouble - GringoRojo - 31-05-12 so when will you realise it wasn't your car but an identical one parked where you thought you'd left yours? Re: Cage trouble - pete786.u - 31-05-12 Phoned my local main agent today to see what the parts would cost :eek £672.62. I think the car will be on it`s way to the scrapyard in the next few weeks, Tax runs out end of July MOT next February the cars not worth spending that much money on it so it`s going. Re: Cage trouble - GrahamB - 31-05-12 This happened to a family member last year. I was able to remove the ignition barrel assembly, identify the worn pins, remove them & put it all back together. I think a combination of worn pins internally & worn key were enough to stop it all from doing the business. I would be tempted to phone a few local breakers before ditching the car myself... . unless you're looking for an excuse to ditch it that is? Re: Cage trouble - robby boy - 31-05-12 What type of car is it, secondhand parts might be readily available cheap. Re: Cage trouble - Lawrence - 01-06-12 Get bits from a breaker/ebay, will be far cheaper than going to a dealer. |
