Brakes - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: FZS600 Fazer (https://foc-u.co.uk/mybb/forumdisplay.php?fid=78) +--- Thread: Brakes (/showthread.php?tid=58834) |
Brakes - Fazer Jake - 26-05-12 Just changed my pads to EBC bedding them in at the moment i noticed they do rub a touch (it will still rotate 1 turn easy) then do get hot after riding and when i brake at high speeds i do feel some slight vibration through the handle bars. is this normal until the pads break in? Re: Brakes - Motorbreath - 26-05-12 sounds as warped disc. You didn't apply any force against it to extract the old pads, did you? Re: Brakes - Fazer Jake - 26-05-12 (26-05-12, 06:18 PM)Motorbreath link Wrote: sounds as warped disc. You didn't apply any force against it to extract the old pads, did you? Just went for a 12mile ride does not seem to be vibrating anymore however does get hot Re: Brakes - CRH - 26-05-12 just done the same this last week! new sbs in front? ..but i had stripped and cleaned calipers/greased upn with rubber grease etc ??...bedded in now!!..no judder whatsoever??....either slight warp on disc/discs?....or pistons only working one side of caliper?? Re: Brakes - CRH - 26-05-12 if they are getting abnormaly hot?...then that will warp your discs??....chk your pistons in calipers are free?? Re: Brakes - HarryHornby - 26-05-12 Got mine back from the garage today after having new EBC HH sintered pads fitted and new calliper seal kits fitted on front, got home, all of a mile in distance, knelt down for a quick inspection and the discs were HOT, I could touch them, but they were hot, never had this before, I've had luke warm but not hot. I'm hoping it's like this while they bed in.....we'll see after the commute on Monday....little concerned now
Re: Brakes - darrsi - 27-05-12 I would SERIOUSLY consider reading about my troubles a few posts down on the forum, titled "[color=rgb(51, 68, 102)]FRONT BRAKE CALIPERS / BRAKE JUDDER[/color]" Re: Brakes - Fazer Jake - 27-05-12 Its sorted itself out :rolleyes no more rubbing after a 30 mile rideout. There is some juddering however i think this is off the road surface as it happens at high speed braking when the forks are maxed out |
