tyre pressure - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: FZS600 Fazer (https://foc-u.co.uk/mybb/forumdisplay.php?fid=78) +--- Thread: tyre pressure (/showthread.php?tid=58793) |
tyre pressure - rufus t glasgow - 24-05-12 hi all a wee quickie... what are the correct tyre pressure's for a 98 fazer? i have 'aqquired' a haynes manual pdf , however it is missing the 'daily pre-ride checks' where this info is. any help would be great. Re: tyre pressure - ddtwelve - 24-05-12 Öooo not a tyre pressure question :lol Re: tyre pressure - Buzz - 24-05-12 Manual says - 32/36 for 98-01, 33/36 for 02/03 With passenger or high speed - 32/40 for 98-01, 33/42 for 02/03 Re: tyre pressure - darrsi - 24-05-12 I've always used 36/42, as i think a lot of other people do too. Mind you, i'm not exactly the smallest person, i occasionally have passengers, and i've got a top box. Whenever i get my tyres changed my mechanic uses those pressures as well. Re: tyre pressure - Fazer Jake - 24-05-12 For best tyre wear i'd go 36/42 Re: tyre pressure - Fazerider - 24-05-12 I've found 34/37 psi to be the best with Bridgestone BT021s. I'm fairly light though, you'll want more air than that in them if you're of average weight. Re: tyre pressure - rufus t glasgow - 24-05-12 (24-05-12, 01:43 PM)Fazerider link Wrote: I've found 34/37 psi to be the best with Bridgestone BT021s. define average weight. i was 102kg the last time i checked. :eek i always ran about 2psi over recommended on my old divvy. but thanks all that certainly gives me a starting point. Re: tyre pressure - Fazerider - 24-05-12 (24-05-12, 02:24 PM)rufus t glasgow link Wrote: define average weight.Blimey! So that's about 40kg more than me. :o Oh well, I may be a weed, but I'll accelerate quicker. :rollin Stick with the 36/42 suggestion and experiment, my freakishly low pressures won't suit you at all! Re: tyre pressure - CRH - 24-05-12 i allways run 34/ 38 on whatever tyres ive got on?....ime 17st nand built like a handsome brick shithouse!!..handlings allways been spot on!!!...2002 foxeye> |
