chain tension - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: Fazer 1000/FZ1 corner (https://foc-u.co.uk/mybb/forumdisplay.php?fid=75) +--- Thread: chain tension (/showthread.php?tid=58789) |
chain tension - thedog28 - 24-05-12 Hi guys and gals, I know this has prob come up b4, but cant help to refresh us lesser mortals lol I never get my drive chain tension perfect, never seem happy with it , so , what is the concensus on adjusting it correctly/best, i had read just resting on the s/arm rubber, 50 mm etc, but in genral, what is the norm we are using here ? Cheers. Rob Re: chain tension - tomjimtom - 24-05-12 Did it yesterday, I did it so the chain was just not touching the swingarm. Would have done it so the tightest spot was just shy of the rubber (WHEEY) but I've got a scotoiller so don't have any tight spots 8) I should also say, this is the first time I've done it since getting the bike 2 years ago (I've checked it though!!) Re: chain tension - thedog28 - 24-05-12 sweet, thats good going, i will invest when its time for new chain n sprockets... so the bottom of the top run is just away from touching the rubber , on center stand ? yes thanks m8y Re: chain tension - Falcon 269 - 24-05-12 (24-05-12, 09:56 AM)thedog28 link Wrote: sweet, thats good going, i will invest when its time for new chain n sprockets... so the bottom of the top run is just away from touching the rubber , on center stand ? yes No! Top of the bottom run should just kiss the underside of the chain guide under the swingarm, tested at the tightest part of the chain, with the bike on the centrestand. Correct spec is 40 - 50mm but this technique is a quick and easy check. Re: chain tension - tomjimtom - 24-05-12 Aye, what Mike said ![]() sorry, should have said that ![]() Re: chain tension - VNA - 24-05-12 I always think, if in doubt go a touch on the slack side, chain and sprockets will potentially/theoretically wear a tad quicker but you won't wreck your gear box or worse snap your chain. Refer to owners manual, there should be a diagram and slack measurement. Use a rule to check the slack at the tightest part of the chain. Or Mikes rule is about the correct amount (you'll see if you check it with a rule) Yes, on the Gen1 thou the chain will slap the swing arm when correct set, hence that plastic thing to protect the swing arm. So yes I second Mike. Re: chain tension - thedog28 - 29-05-12 ty guys , ill work with that , at least it will give me a constant to work with
