RPM clock doing weird things - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: Fazer 1000/FZ1 corner (https://foc-u.co.uk/mybb/forumdisplay.php?fid=75) +--- Thread: RPM clock doing weird things (/showthread.php?tid=58649) Pages:
RPM clock doing weird things - FuZzBoM - 15-05-12 Hi all, I have had an epic 4 days in Ireland covering over 1200 miles.. my 51 plate fazer has been spot on and not missed a beat. however... leaving the ferry i noticed my RPM guage doing odd things while ticking over. flicks to 0rpm then to 7000rpm and then back to 0 again. it keeps doing this till i ride off and then the guage sits at normal RPM's while riding. It done this pretty much all the way home from what i could see. any suggestions to what this could be? thanks, Re: RPM clock doing weird things - Tmation - 15-05-12 Your EXUP valve is not operating properly, either its sticking or the cables are out of adjustment, thats the error code for it. lots of info on here on how to sort it and here; [size=78%]http://www.cartestsoftware.com/fz1/exupmaintenance.html[/size] and for the main page of loads of other useful stuff [size=78%]http://www.cartestsoftware.com/fz1/[/size] Good luck Re: RPM clock doing weird things - ghostbiker - 15-05-12 as above, its Exup fault code. Pats site (the above link) is a great guide on how to service it. its something that not included in the normal service so is overlooked and needs regular maintanance. once you get used to it, it takes 10-15 mins tops. but for first time take you time and soak all bolts in pen fluid for a few days before trying to remove them. Re: RPM clock doing weird things - FuZzBoM - 15-05-12 Cheers for the info guys. most helpful. i will check the valve out after work. Do we have a list of fault codes for future reference? thanks, Re: RPM clock doing weird things - ghostbiker - 15-05-12 the ones i know off hand are 3k is TPS (throtle postion sensor) 4k i think was something to do with speedo sensor 7k exup fault 9k is i think the lean angle thing. to cut the bike out when it falls over. from memory so dont take them as gospal Re: RPM clock doing weird things - mcyoungy - 15-05-12 yep they're right Re: RPM clock doing weird things - sadlonelygit - 15-05-12 ignore them, it's totally focc'd. i'll do you a favour and take it off your hands for £500..........for a mate like! Re: RPM clock doing weird things - FuZzBoM - 15-05-12 haha funny man. i must admit i do feel guilty.. it was a mint one i picked up about a month ago with 5000 miles on the clock. its now in my garage looking filthy with an extra 1500 miles on it since i got it. Re: RPM clock doing weird things - red98 - 15-05-12 its all about the ride....enjoy your fazer Re: RPM clock doing weird things - FuZzBoM - 16-05-12 Washed the poor thing this evening and took it for a quick run to get any standing water off. oddly it seems to have cured itself as it no longer flicks from 0 to 7000 rpm and pulls just like it did before. However i still plan to open her up and give it a clean and check the cables etc. Re: RPM clock doing weird things - ghostbiker - 17-05-12 Get on top of the exup as once you do its easy to keep on top of. Also just because the 7k fault isn't showing dosent meen there is not a problem. I once had the exup jam when I hit a rock doing some off road in Scotland. Yet it didn't show a fault. And I have had a fault code when there was no fault as such but the cables were not set right It's an odd thing for sure LOL. Re: RPM clock doing weird things - FuZzBoM - 17-05-12 Well I attempted to open it all up but the Alan bolts are seized solid... Covered them in wd40 but no joy. Even a knock with a hammer wouldn't budge them. Decided to leave it over night and see if the wd40 penetrates. The cables were well out of alignment so at the very least the fault shouldn't come back. Cheers all. Re: RPM clock doing weird things - solorider - 17-05-12 (17-05-12, 10:45 PM)FuZzBoM link Wrote: Well I attempted to open it all up the the Alan bolts are seized solid... Covered them in wd40 but no joy. Even a knock with a hammer wouldn't budge them.wd40 is not a penetrating fluid,you need a proper penetrating fluid like plusgas or similar,and get some heat on the bolt,when you reassemble the exup fit some stainless bolts,i got mine off ebay in the correct lengths Re: RPM clock doing weird things - Falcon 269 - 18-05-12 I foresee stripped bolt heads, a gnashing of teeth, great wailing in distress and a flurry of posts here. Read this now and you'll be emotionally prepared for what's to come: http://fazerowners.yuku.com/topic/21517 Hey, you might even get lucky, learn a few dodges to ease those bolts out and avoid the worst. Probably not but here's wishing you luck. And +1 on the use of proper penetrating fluid and heat. And prayer! Don't waste your time trying again today. The WD40 won't have done any good. Even pukka penetrating fluid will need several nights of application before it does the job ... clean off the corrosion all around to give it a better chance of reaching the threads, too. Re: RPM clock doing weird things - ghostbiker - 18-05-12 Damn, bad luck on the stuck bolts. As above use a good pen fluid and above all don rush it. give the bolts a good coat of it once or twice a day for at least 3 days and better to go a weak if you can. if they do snap it isnt the end of the world though. the exup is a common problem but 90% of it is caused by lack of maintanace. it may be a pain to fix now but once done it realy is a quick and easy thing to keep on top of. i tend to service mine twice a year, i used to do it everytime i saw a post about exup problems but i ended up doing it weekly at one point ![]() Good quality Stainless steel bolts to replace the old ones is a must as well. i coat them well with coppa slip and use a spring washer on them (spring washer meens you dont need to torque them up to tight and easyer to undo them next time) If you happen to go to the peterbrough BMF show this weekend i have a few sets of exup bolts and washers i allways take to the owners club stand. but any good hardwear store will have them to. Re: RPM clock doing weird things - FuZzBoM - 18-05-12 Any idea what size the bolts are? they look like they could be about an M4 but hard to tell with them stuck in lol.. just thinking i will change them for some stainless ones IF i ever get them out. but would be nice to have them ready to just replace them. Funny enough i was discussing with a mate about the BMF but alas i am busy this weekend so i am unable to make it
Re: RPM clock doing weird things - solorider - 18-05-12 (18-05-12, 12:31 PM)FuZzBoM link Wrote: Any idea what size the bolts are? they look like they could be about an M4 but hard to tell with them stuck in lol.. just thinking i will change them for some stainless ones IF i ever get them out. but would be nice to have them ready to just replace them.they are m6,i think the short cover screws are 10mm long which i had to use a washer and the inner cover screws are longer but you can get away with 10mm,the cover screws will bottom out if they are too long Re: RPM clock doing weird things - FuZzBoM - 19-05-12 Full marks go to Falcon 269 for his accurate prediction... apart from the great wailing bit because after his post i expected the worst and no surprise all 3 sheared clean off. as suggested proper penetrating fluid and even a blow torch but no luck 1 did tease me and started to come out but the bolt was to weak to take it.In truth it does not look like its ever been off so i am not surprised. Now then, do i try and drill them out in situ or shall i take the exhaust off. i am thinking the latter tbh. Re: RPM clock doing weird things - FZ_Rich - 19-05-12 Well my exup was squeaking when it closed and my main stand was too so I thought while I'm waiting for rear shock to be sorted I'd slap some coppergrease around. Sheared allen head bolt on exup end plate. Bust Cable Pulley (cables were rusted in solid). Sheard 1 exhaust stud into the head. Other than that it's not too bad :\ Re: RPM clock doing weird things - solorider - 20-05-12 hopefully your down pipes wont be as bad as mine was to remove as shown on this post http://foc-u.co.uk/index.php/topic,2330.0.html i had to dremel the exup bolts off as the heads had long disapeared because of rust |
