speedo stoped working - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: FZS600 Fazer (https://foc-u.co.uk/mybb/forumdisplay.php?fid=78) +--- Thread: speedo stoped working (/showthread.php?tid=58598) |
speedo stoped working - ernst - 12-05-12 :\ hi all,out on the bike today and doing about 60 ish and speedo just droped and hasnt worked since,any ideas guys .everything else electric wise is ok?does it have a fuse for the speedo alone?or any common faults with speedo,s help!! Re: speedo stoped working - how.do@ntlworld.co. - 12-05-12 Speedo works from sensor on front wheel near side. Check the wire to sensor is okay. Mine went funny after I let a garage change the pads and they trapped the wire to the sensor in the process. Every since I have done my own service etc. Re: speedo stoped working - Dunky - 12-05-12 More than likley it will be the ceramic drive dog inside the speedo sensor (one of the small tabs snapped off) you will get one for about £20 new. Hope this helps. Dunky.................. Re: speedo stoped working - red98 - 12-05-12 (12-05-12, 08:53 PM)Gunky link Wrote: More than likley it will be the ceramic drive dog inside the speedo sensor (one of the small tabs snapped off) you will get one for about £20 new. iam with you dunky...same thing happened with mine....easy to fit
Re: speedo stoped working - fazervic - 12-05-12 £20.00 why did i get quoted £140.00 for a new sensor, :eek Re: speedo stoped working - solorider - 12-05-12 (12-05-12, 09:35 PM)fazervic link Wrote: £20.00 why did i get quoted £140.00 for a new sensor, :eekit could be the sensor but i would pop the wheel off and check the drive dog first,hopefully that is your fault and as mentioned the most common fault Re: speedo stoped working - red98 - 13-05-12 (12-05-12, 08:55 PM)red98 link Wrote: [quote author=Gunky link=topic=2949.msg23402#msg23402 date=1336852411] iam with you dunky...same thing happened with mine....easy to fit [/quote] oops..........sorry GUNKY Re: speedo stoped working - red98 - 13-05-12 (12-05-12, 09:35 PM)fazervic link Wrote: £20.00 why did i get quoted £140.00 for a new sensor, :eek £20 quote will be for the drive dog which i think is the problem here,£140 could be right for the sensor knowing what yamaha prices are like
Re: speedo stoped working - Captain Haddock - 13-05-12 Mine stops working occaisionally and I give it a whack and it works again, I like to call it 'percusive maintenence'. Re: speedo stoped working - Dunky - 13-05-12 Red98 you were correct the first time the name is Dunky mate someone thought it would be funny to alter it due to a remark that was said. Re: speedo stoped working - ernst - 13-05-12 thanks for your suggestions chaps ,will have a look in the morning hopefully an easy fix,last time the wheel was off was about 500 milles ago when i got a new tyre,refitted the wheel myself so if the wires trapped only got me to blame,will let you know as soon as,cheers. Re: speedo stoped working - ernst - 16-05-12 problem sorted it was the drive lugs snapped off,£17 from yamaha main dealer it looked like they are different with plastic ring and drive tabs but fit and worked ok, :lol happy days,thanks for all your help guys,
Re: speedo stoped working - red98 - 16-05-12 glad you got it sorted
Re: speedo stoped working - Dunky - 16-05-12 Result :thumbup |
