clutch return ?? - Printable Version
+--- Thread: clutch return ?? (/showthread.php?tid=58560)
clutch return ?? - ddtwelve - 08-05-12
hi does anyone have this problem no matter how much i adjust the clutch cable when i release the clutch lever there is always have to push it back 1-2 mm to its stop
does it need a new cable, clutch, return spring??
Re: clutch return ?? - mcyoungy - 09-05-12
No it's fine. Stop worrying and ride your bike.
If you remove all slack from the cable you stand the chance of not having the clutch fully engaged, so it will slip and wear faster.
Re: clutch return ?? - dolau - 23-05-12
I wondered that and even lubricated the cable but it was no better :o
