Seat Height - Adjusting ? - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: FZS600 Fazer (https://foc-u.co.uk/mybb/forumdisplay.php?fid=78) +--- Thread: Seat Height - Adjusting ? (/showthread.php?tid=58541) |
Seat Height - Adjusting ? - Enceladus - 07-05-12 hi all love this forum ![]() just ordered my first 600 fazer and i can't wait to take delivery next week ! the first thing i'll need to do though is drop the seat height being a bit short in the leg ! how easy is this to do, and how do you do it ? thanks ![]() Re: Seat Height - Adjusting ? - Skippernick - 07-05-12 Hi there Not sure which year your bike is but i'm not sure you can, mines an 02 fazer and you can't. Maybe you can with a later model and i'm sure someone will be on soon t let you know. Nick Re: Seat Height - Adjusting ? - richfzs - 07-05-12 You can get the foam cut down, and then re-covered. Been a few people done that - there's a guy in Huddersfield has a reputation for quality work (Tony Archer, I think his name is) Re: Seat Height - Adjusting ? - Enceladus - 07-05-12 thanks ![]() my bike is a 2001 model so i guess i'll have to get the foam cut down. Re: Seat Height - Adjusting ? - richfzs - 07-05-12 http://www.tonyarcher.co.uk/ Re: Seat Height - Adjusting ? - Enceladus - 07-05-12 thanks for the link
Re: Seat Height - Adjusting ? - YamFazMan - 07-05-12 Hi I you feel confident do it yourself, I did mine with an electric carving knife and smoothed and blended the shape with course sand paper then restapled the cover on. (I only unstapled the front half of the seat) If your only looking for a small redution in hight remove the four rubber bungs from under the seat this gives about 12mm or 1/2'' on old money ATB YFM Re: Seat Height - Adjusting ? - Enceladus - 07-05-12 thanks for the tip. probably a 1/2" reduction will do the job. i can get both feet on the floor but not fully, so an extra 1/2" could do the trick
Re: Seat Height - Adjusting ? - Skippernick - 07-05-12 Another way would be to change your riding style, you only need one foot on the ground at a time either holding the rear brake whilst stationary or selecting gear. That way you keep your right foot off the ground away from passing traffic etc especially if your next to a car at lights etc. Just a thought. Re: Seat Height - Adjusting ? - solorider - 07-05-12 you could also fit longer bones,that would lower the rear of the bike and also lower the forks a bit,but it would lower your ground clearence Re: Seat Height - Adjusting ? - Oxygen - 07-05-12 This might work http://www.shortsupport.org/Health/Leg-Lengthening/ Re: Seat Height - Adjusting ? - Fazerboy - 09-05-12 Was in the same boat when I got another Fzs600 I had both the Longer dog-bones and a custom seat, makes all the difference No longer need either, replaced the dog-bones with originals and the Custom seat is in the Garage PM me if your interested in either ok Re: Seat Height - Adjusting ? - gassitt - 11-05-12 Or you could do it the stylish way and fit a shorter Hagon shock . No messing with seat and a straight bolt on . As luck would have it I have said item plus shortened sidestand to suit All in £ 80 Pick up in Manchester or post whatever Re: Seat Height - Adjusting ? - Enceladus - 20-05-12 having removed the 4 rubber "bungs" the seat is now pretty much perfect for me ![]() just a thought though, would that lead to scratching / rubbing of the seat on the frame ? if so, what could i use to prevent it without altering the seat height (too much) ? thanks Re: Seat Height - Adjusting ? - YamFazMan - 20-05-12 Hi After removing the 4 rubber bungs I made some small spacers with longer bolts for in between the frame and the seat holding catch. which moved the catch down held the seat more securely. I can not recall how long the were. ATB YFM Re: Seat Height - Adjusting ? - arch33angel - 20-05-12 That's a brilliant looking bike Fazerboy! |
