Missing buttons: FZS 1000, 05' - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: Fazer 1000/FZ1 corner (https://foc-u.co.uk/mybb/forumdisplay.php?fid=75) +--- Thread: Missing buttons: FZS 1000, 05' (/showthread.php?tid=58512) |
Missing buttons: FZS 1000, 05' - b1k3rdude - 04-05-12 Just noticed the other day my 05' is missing the hazard and hi beam flash switches.. 1. why would they be missing..? 2. is the circiutry still there, could I just buy a left hand switch gear with the aforementioned buttons and fit..? ta. Re: Missing buttons: FZS 1000, 05' - mcyoungy - 04-05-12 import bike? do you have headlamps auto on or do you have a light switch? Re: Missing buttons: FZS 1000, 05' - b1k3rdude - 05-05-12 (04-05-12, 11:14 PM)mcyoungy link Wrote: import bike? do you have headlamps auto on or do you have a light switch?The paperwork dosent show anything, but it could be an import from a contry that has mph I guess..? and all FZS1000's after 2004 have auto on lights. Re: Missing buttons: FZS 1000, 05' - Tmation - 05-05-12 My 2004 doesn't have hazard switch or Hi beam flasher. I think it is one of the small differences between the 2001-2003 and the 2004-2005 Gen 1's Re: Missing buttons: FZS 1000, 05' - VNA - 05-05-12 Weird, my 2004 models has the hazard switch. The on/off switch for the headlamps is banked off, as you would expect. Looking at bike trader, 2005 models all have hazard switches too. Re: Missing buttons: FZS 1000, 05' - thecert - 05-05-12 My 05 has the red hazzard switch and a high beam "pass" flasher switch, how strange that yours has'nt. Re: Missing buttons: FZS 1000, 05' - tomlinscote - 05-05-12 Ditto the above, mine is an '04 and it has both. Though can't say I ever use them much, if at all! Re: Missing buttons: FZS 1000, 05' - Tmation - 05-05-12 Forgot to say mine is an import from USA, although it doesn't say it on the log book and when I do an insurance search it doesn't come up as an import either.
Re: Missing buttons: FZS 1000, 05' - Tmation - 05-05-12 And from the other side.
Re: Missing buttons: FZS 1000, 05' - b1k3rdude - 06-05-12 Ok good to see Im not the only one then, that bring us back to the wiring question. Changing the switchgear and wiring in the flasher will be a piece of cake, but the big question is the wiring there for the hazard circuit? And for that matter how does the hazard circuit work as I have only ever known gen1 fazer to have a simple 3 pin flasher, does the hazard switch complete the left and right circuits at the same time etc...? Re: Missing buttons: FZS 1000, 05' - Tmation - 06-05-12 There are at least two different wiring diagrams, check out the Yam workshop manual or Haynes. I bought a used left hand switch gear and the wiring had different connectors so wouldn't fit, luckily I only needed some of the parts inside the switch. Re: Missing buttons: FZS 1000, 05' - b1k3rdude - 06-05-12 (06-05-12, 03:03 PM)Tmation link Wrote: I bought a used left hand switch gear and the wiring had different connectors so wouldn't fit, luckily I only needed some of the parts inside the switch.yeah that's what I'm thinking, it should be easy enough to retro fit. |
