scottoiler advice. - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: FZS600 Fazer (https://foc-u.co.uk/mybb/forumdisplay.php?fid=78) +--- Thread: scottoiler advice. (/showthread.php?tid=58479) |
scottoiler advice. - para300 - 02-05-12 Hi there, [/size]I've recently picked up my first big bike in the form of a Fazer600 fitted with a scottoiler. The device seems to be doing a pretty good job to date and i have noticed that the oil will need replenishing shortly. As a result I purchased a new bottle of standard scottoiler oil. It arrived today and just as i was about to top up the reservoir i noticed the oil in the reservoir was of a reddish colour and the scottoiler oil in the bottle was of a blue shade. At this point I stopped. I am concerned that mixing the two different oils could cause a problem. I have heard that the oil colours have changed to prevent confusion between the traditional and thin oils. whats your thourghts on mixing these two oils or should i leave well alone and attempt a complete change of oilregards Para300 Re: scottoiler advice. - topgun44 - 02-05-12 should be ok but can u send it back and get blue oil i use blue all the time
Re: scottoiler advice. - clayt74 - 03-05-12 there is no problem in mixing the two types, which one you choose to use will depend on where your reservior is situated (is it close to a constant heat source) and whether or not you intend to use the bike all year round or just summer? basicaly the red oil is recommended for ambient temps between 20 - 40C blue is recommended for ambients between 0 -20C which ever one you choose the flow rate will still need adjusting through out the year. blue is the standard oil recommended for UK use, and i use it all year round. hope that helps Re: scottoiler advice. - Fazerider - 03-05-12 It'll be fine, though you may find you need to adjust the flow rate control if it's viscosity is slightly different. Or you could do what I do, use cheap car engine oil instead of the overpriced stuff from Scottoil. Re: scottoiler advice. - janner_10 - 03-05-12 (03-05-12, 08:56 AM)Fazerider link Wrote: It'll be fine, though you may find you need to adjust the flow rate control if it's viscosity is slightly different. This is what I do - my chain gets sprayed with my old engine oil!! Re: scottoiler advice. - JZS 600 - 03-05-12 My bike came with a Scottoiler fitted. Once it run out, I never filled it again as I was fed up with the stuff flying everywhere... Chain Lube once a week after the bikes been ridded so the chain is warm. Re: scottoiler advice. - topgun44 - 03-05-12 (03-05-12, 03:54 PM)JZS 600 link Wrote: My bike came with a Scottoiler fitted.mmm mind do not u do get some waste i got my to oil drop once avery 3 mins it was 2 drops a min thats was mess every where just it down a bit see what happed
