Chain cleaning - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: Fazer 1000/FZ1 corner (https://foc-u.co.uk/mybb/forumdisplay.php?fid=75) +--- Thread: Chain cleaning (/showthread.php?tid=58465) |
Chain cleaning - shooter - 01-05-12 My chain could do with a good clean. Do I need to remove the rear hugger or is it easier to try and work around it? I have a 2002 model. Re: Chain cleaning - tomlinscote - 01-05-12 might be worth taking it off so you can clean any old crud off of it. what do the rest of you guys use to clean the chain that really works without damaging the rubber seals? Cheers, P Re: Chain cleaning - mcyoungy - 01-05-12 I've always used WD40 to clean the chain. It breaks down the oil gunge nicely. Doesn't affect the o-rings. Wipe it off with a rag. Then a wipe over with Scotoil and run a Scotoiler on it. Lovely. Re: Chain cleaning - ddtwelve - 01-05-12 take it for a 15min ride first to soften up all the oil grease etc for cleaning http://youtu.be/4zxbKr73vDQ if a girl can do it you can :lol Re: Chain cleaning - ddtwelve - 01-05-12 wheres cheapest place for grunge brush?? Re: Chain cleaning - mcyoungy - 01-05-12 your old tooth brush or a stiff paint brush or a bottle brush paint brush is best tbh. you don't need to go nuts on it. Re: Chain cleaning - ghostbiker - 01-05-12 i use a couple of cheap nail brush's. easy to use on the chain and work the dirt off fast. I want to say i use parafin to clean it but now i say that im not 100% sure thats what i use and i cant be arsed to go dig it out of the cupboard to check lol Re: Chain cleaning - GrahamB - 01-05-12 I use white spirits & an old paint brush with half the bristles chopped off. No, not the left half or the right half, the first half of all the bristles. :look Re: Chain cleaning - mcyoungy - 01-05-12 top half or bottom half? Re: Chain cleaning - tomlinscote - 01-05-12 depends which way up you hold it! Re: Chain cleaning - GrahamB - 02-05-12 The half furthest away from the handle.
Re: Chain cleaning - pitternator - 02-05-12 WD40 always...its great for cleaning , and being a water disperser and lubricant , wont harm the chain.Some guys just use wd as a lubricant too..
Re: Chain cleaning - mcyoungy - 02-05-12 WD40 is also the easiest way I've found of getting the fling off the back wheel. Chain cleaning - cable tie - 02-05-12 (02-05-12, 09:03 AM)mcyoungy link Wrote: WD40 is also the easiest way I've found of getting the fling off the back wheel. And it gets grease/oil/grass stains off your clothes as well. Re: Chain cleaning - mcyoungy - 02-05-12 I wonder if you can use it for cooking or bathing the dog? Re: Chain cleaning - ghostbiker - 02-05-12 Cooking your dog? Re: Chain cleaning - keithfzs1000 - 02-05-12 Do gay garage mechanics use it :eek :eek :eek i have heard its a good lubricant :lol :lol :lol :lol Re: Chain cleaning - VNA - 02-05-12 Never cleaned a chain in ma puff. Re: Chain cleaning - DryRob - 02-05-12 You could make a cleaning brush... http://www.bikechatforums.com/viewtopic.php?p=2830262 Re: Chain cleaning - mcyoungy - 02-05-12 that's brilliant. or do i mean stupid? :lol |
