Carburetor 4-Way Crossover Equalization Manifold Set-up - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: Fazer 1000/FZ1 corner (https://foc-u.co.uk/mybb/forumdisplay.php?fid=75) +--- Thread: Carburetor 4-Way Crossover Equalization Manifold Set-up (/showthread.php?tid=58399) |
Carburetor 4-Way Crossover Equalization Manifold Set-up - cable tie - 26-04-12 Ayup chaps, im looking for a some feedback and info as to your set up on the above ! Now ive seen this on pats page and have the various pipes to do the job. 6mm pipe: as per pat's but note the pipe is huge of the spigots 5mm pipe: this fits better Do i do the 4 link-up method or 1-4 / 2-3 method so my Q what would be the best method or the best tried method by yourself. Dave :think Re: Carburetor 4-Way Crossover Equalization Manifold Set-up - ghostbiker - 26-04-12 I did the 1 - 4 2-3 method. But honestly I didn't realy notice a diff between the methods. And the first way just seemed over complicated so I simplified it to the 2nd way. Re: Carburetor 4-Way Crossover Equalization Manifold Set-up - GrahamB - 27-04-12 A complete waste of time I found.. . much like the mirror mod.
Re: Carburetor 4-Way Crossover Equalization Manifold Set-up - cable tie - 27-04-12 I got rid of the vibes in my bars and im trying to get rid of some vibes i have in the pegs (lsl rear sets) and have done about everything there is too do apart from the the above so will this make any difference!! i note when i remove the exhaust can hanger from the rear peg the vibes are gone and putting my hand on the can i can feel the vibes. Dave . Re: Carburetor 4-Way Crossover Equalization Manifold Set-up - Falcon 269 - 27-04-12 Dave, you're trying to remove vibes from a bike which has an unbalanced 4-cylinder motor. There will always be secondary vibes as a result. All sorts of things can affect the transmission of those vibes around the bike, like the exhaust can for example. I found fitting the Akra headers and can reduced vibes felt. Lead shot in the bars did nothing, though. A full tank of fuel changes the vibe characteristics, too. I also have LSL footrests but those are vibe-free on mine. As for the carb X-over mod, like Graham B, I found it a complete waste of time. Re: Carburetor 4-Way Crossover Equalization Manifold Set-up - jackojet - 27-04-12 No vibes as such on mine . i have renthal bar end plugs not weights, and when i had gilles rearsets fitted no vibes in them ( sold to Kosmic) there is some tingerling but i consider the feel of that makes me feel connected to the engine, more feeling the bike is alive
Carburetor 4-Way Crossover Equalization Manifold Set-up - cable tie - 27-04-12 Yeah it's more a tingling in the pegs I notice it very slightly in the tank as well at about 2500 rpm but wind the throttle on and it does disappear, I did fill the pegs on the Lsl sets as there hollow with melted lead to make a lead bullet not sure if it worked or not ! I'll give the linking up the carbs a miss I think than, I did buy a Morgan carbtune last night of evilbay so I'll see if the carbs are out, I did have vibes in the bars but I sorted them and they are vibe free now. Dave Re: Carburetor 4-Way Crossover Equalization Manifold Set-up - karlo - 27-04-12 Could try a rubber mount for the exhaust? http://www.ebay.co.uk/itm/Anti-Vibration-Mount-Rubber-Bobbin-Mounting-M8-B3325-/160784367672?pt=LH_DefaultDomain_3&hash=item256f7ec038 Re: Carburetor 4-Way Crossover Equalization Manifold Set-up - solorider - 28-04-12 going back to the very early 80s yamaha had YICS on some of the bike which linked the 4 cylinders with a channel in the cylinder head,that worked on those engines as the channel was 10mm and it was near the ports,the idea was as a cylinder was on induction it would drag some mixture from the othe carbs,this would cause swirl within the combustion chamber giving better combustion,it did work on those engine because they were 8 valve,a modern 16 valve or 20 valve engine has natural swirl in the combustion chamber and a better combustion chamber shape so the linking of the ports wont work,and as the pipes are in the inlets they are too far away anyway.yamaha only ever fitted YICS on one multi valve engine and that was a v twin XZ550,that was by pipes and it did not work on that either |
