Fuel tank breather hose leak - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: Fazer 1000/FZ1 corner (https://foc-u.co.uk/mybb/forumdisplay.php?fid=75) +--- Thread: Fuel tank breather hose leak (/showthread.php?tid=58204) |
Fuel tank breather hose leak - binarystarr - 11-04-12 Hi all Just noticed fuel is dripping from the fuel tank breather hose. Any ideas as to what could be causing that? Re: Fuel tank breather hose leak - Falcon 269 - 11-04-12 You sure it's the tank breather hose and not the carb overflows? If the latter, suspect sticking float (fairly significant outflow, though), a leaky float needle (not common) or a leaky float needle seat O-ring (a lot more common). http://www.yamahafz1oa.com/forum/showthread.php?t=103599&highlight=found+carb+failure+mode Re: Fuel tank breather hose leak - Phil TK - 11-04-12 (11-04-12, 01:46 PM)Falcon 269 link Wrote: If the latter, suspect sticking float (fairly significant outflow, though), My FJ suffered from that until I got the carbs out and cleaned the bowls and float pivot -and replaced o rings and needle jets. However a temporary cure that often worked was to whack the errant carb bowl a few times with the end of a wooden hammer handle. Re: Fuel tank breather hose leak - locksmith - 11-04-12 I concur, a couple of sharp taps on the carb bowl can be effective. Re: Fuel tank breather hose leak - binarystarr - 12-04-12 Many thanks guys, haynes manual arrived today so will be out this weekend with the tool kit. I suspect i may have possibly overfilled the tank but this is a good excuse to get my hands dirty and check a few things over. Re: Fuel tank breather hose leak - taksi - 12-04-12 My injected '08 FZ1 does it as well in the sun. No carbs to bash so any other ideas? Taksi Re: Fuel tank breather hose leak - Falcon 269 - 12-04-12 Just a wild guess ... too much fuel, expanding when it gets warm? Re: Fuel tank breather hose leak - binarystarr - 13-04-12 Falcon, i think thats more than likely the problem. Only thing is it didn't leak until several days after filling. I guess it may take a while for it to condense and make its way down the tube. I'm not too worried. Will keep an eye on it and get greasy in the meantime. Re: Fuel tank breather hose leak - Falcon 269 - 13-04-12 Leaking due to overfilling/expansion would normally be immediate to my mind. Has it been raining on the bike recently? I wonder if you've had water get around the tank cap and find it's way out via the overflow hose. |
