bleeding the back brake??? - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: Fazer 1000/FZ1 corner (https://foc-u.co.uk/mybb/forumdisplay.php?fid=75) +--- Thread: bleeding the back brake??? (/showthread.php?tid=58149) |
bleeding the back brake??? - adam1000 - 07-04-12 Does anybody know of any tricks to sucessfully bleeding the back brake? i have fitted a new hose and used the traditional bleeding method, i have no air bubbles coming through but its still not near as good as it was!! Re: bleeding the back brake??? - mcyoungy - 07-04-12 I use a syringe on the bleed nipple to put suction on the line then keep pumping. If the pedal is soft you've still got air in the caliper. Re: bleeding the back brake??? - garysimmo - 07-04-12 disconnect the soft hose at the reservoir end and get yourself a wider ended syringe. then crack the bleed nipple and apply pressure from the res end this then gets rid of any air that may get trapped in master cylinder Re: bleeding the back brake??? - bludclot - 07-04-12 letting the fluid stand over night often helps matters, it then bleeds to a firm lever easily the following day. Re: bleeding the back brake??? - slappy - 08-04-12 i found that dumb perserverance worked,about two bloody hours of it! Re: bleeding the back brake??? - mcyoungy - 08-04-12 can't beat dumb perseverance! :lol Re: bleeding the back brake??? - adam1000 - 08-04-12 ended up wedging the brake pedal down overnight with the lid off, tried it this morning and bang on! Re: bleeding the back brake??? - Falcon 269 - 09-04-12 Possibly a dumb question but have to check ... you are using both bleed nipples, no? Re: bleeding the back brake??? - bikerally - 10-04-12 i bought a mityvac vaccum pump from hein gericke and it worked great, done mates brakes & its now paid for its self. |
