exup spacer missing - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: Fazer 1000/FZ1 corner (https://foc-u.co.uk/mybb/forumdisplay.php?fid=75) +--- Thread: exup spacer missing (/showthread.php?tid=58147) |
exup spacer missing - kerb - 07-04-12 Hi All looking for a bit of help , i recently bought 03 fazer thou so i was getting the error code for exup valve when ignition turned on ( rev counter going to 700rpm) so found that exup valve was seized so i striped it down and greased it all up now moving freely with hand but when i tightened up all bolts to torque setting found that valve was very hard to move so i took it out again i found that the spacer was missing ( see spacer on this pic, red arrow pointing to it in pic r/h top ) http://www.cartestsoftware.com/fz1/images/exupmaintenance05.jpg and first part on left in this pic http://www.cartestsoftware.com/fz1/images/exupmaintenance04.jpg so i want to make a spacer for it so my Questions are is this spacer the same diamater as the bushing thats inside it what i mean is , is the outer diamater larger than the bushing thats inside it ( this bushin doesnt normaly come out when valave removed its not in any pics thanks for any info kerb Re: exup spacer missing - kerb - 07-04-12 heres a parts diagram http://www.oemmotorparts.com/oem5.asp?M=Yamaha&T=FZS FAZER 1000&Y=2003&L=YA-FZS-FAZER-1000&O=EXHAUST SYSTEM&F=YA-FZS-FAZER-1000_al&L2=YA-FZS-FAZER-1000_al the inside bushing is no.9 and spacer im missing is no.13 but its about 50 quid postd to me Re: exup spacer missing - mcyoungy - 07-04-12 http://www.yamahamotorcyclespares.co.uk/spares/epc2.asp?PageiD=12&modelID=9753&m=YAMAHA+FZS1000+FAZER+2002++2002+EXHAUST&uID=0 can't read the drawing in your post but you can buy the part online here. Re: exup spacer missing - kerb - 07-04-12 (07-04-12, 12:09 PM)mcyoungy link Wrote: http://www.yamahamotorcyclespares.co.uk/spares/epc2.asp?PageiD=12&modelID=9753&m=YAMAHA+FZS1000+FAZER+2002++2002+EXHAUST&uID=0 thas the part alright , but its still 35 pound posted to me but thanks for info Re: exup spacer missing - kerb - 10-04-12 bump
Re: exup spacer missing - Smokinjoe - 10-04-12 I've just stripped mine out this afternoon The spacer is 15mm outside diameter and 4mm thick and is made from stainless I think as its not magnetic! Check carefully inside the exhaust because the first time I stripped mine out I had the same thing and thought it was missing but on closer inspection I found it inside. It had dropped off when I pulled the valve out. After I had found it I struggled a bit to get it back and that is how I know its not magnetic! If you don't find it I would check the diagram again I think its the bush that's £35 not the spacer! Good luck! Re: exup spacer missing - kerb - 10-04-12 (10-04-12, 06:14 PM)Smokinjoe link Wrote: I've just stripped mine out this afternoon cheers Joe that's a great help i will check this out tomorrow the reason the spacer is 35 pounds to me is cause I'm including postage to ireland as you say maybe its inside cause i just stuck a long magnet in there ( thinkin it was magnetic ) i will report back cheers kerb |
