exup valve info plz - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: Fazer 1000/FZ1 corner (https://foc-u.co.uk/mybb/forumdisplay.php?fid=75) +--- Thread: exup valve info plz (/showthread.php?tid=58052) |
exup valve info plz - busajohn - 30-03-12 Hi everyone..i have just instaled a new can (like a growler) and was wondering what i have to do with the cables from the exup valve ... do i have to snip any wires from ecu or anything like that .and should i remove the cat (honeycome stuff)....thanks for any replies
Re: exup valve info plz - solorider - 30-03-12 you can either tie the cables out of the way or take them off,but you will need to keep the motor plugged in or you will get error codes,as to the cat you have 2 options,one is as you say gut it but if you wanted to put the bike back to standard it will cost you a lot of money and the other is a replacement set of downpipes (assuming that is where the cat is) which dont have a cat,there is some on ebay made by delvic Re: exup valve info plz - busajohn - 30-03-12 solorider...big thanks for ypur reply Re: exup valve info plz - locksmith - 31-03-12 And stop ruining the edge of your tyres top ......
Re: exup valve info plz - busajohn - 31-03-12 the pic of the can is the picture of the can on his site ..bike isnt mine :evil Re: exup valve info plz - busajohn - 02-04-12 now the can is fitted was thinking about doing oil ..filters ... wot air filter should i fit having changed the can..thanks ,,,,John Re: exup valve info plz - ghostbiker - 02-04-12 I could be compleatly wrong here, but I thought on the Gen 2 a Powercomander is pretty much a must before changing to much stuff. but i am not realy up to speed on the gen 2, i prefer a set of carbs ![]() Re: exup valve info plz - locksmith - 02-04-12 You'll never be up to the speed of a gen2 riding a carbed dinosaur ghosty :lol I've always run a std air filter in mine and no power commander :b |
