Meta 357T adding another fob - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: FZS600 Fazer (https://foc-u.co.uk/mybb/forumdisplay.php?fid=78) +--- Thread: Meta 357T adding another fob (/showthread.php?tid=58033) |
Meta 357T adding another fob - FuZzBoM - 29-03-12 Hi all, i have a Meta 357T on my FZS600 only problem is it only has 1 fob. does anyone know anything about getting an extra fob added on? i have read it needs a code put in but i have no idea where to get this and input it even if i had it. any help would be greatly appreciated. thanks in advance. Re: Meta 357T adding another fob - Pat - 30-03-12 You need the security code that is on a red plastic card that the previous owner should have given you, if you don't have it then I'm afraid you're screwed & you can't add another fob. There's more info about it here: http://www.abacuscaralarms.co.uk/alarms/remote_controls/meta-remotes.html Re: Meta 357T adding another fob - FuZzBoM - 30-03-12 Balls.. i expected as much. luckily i do have the addresses of the past 2 owner so might send them letters and see if they still have it. many thanks for info. |
