Rear brake calliper - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: Fazer 1000/FZ1 corner (https://foc-u.co.uk/mybb/forumdisplay.php?fid=75) +--- Thread: Rear brake calliper (/showthread.php?tid=57985) |
Rear brake calliper - greeny - 26-03-12 Hi all, One of the bleed nipples broke off my rear calliper. I want to sort it out but want to get a second calliper first incase it goes all wrong. The only problem is I can't find one any where. The bike is a 53 plate fzs. Anyone know if the rear caliper is a blue spot as standard? And is there any other bike models with same caliper so I can widen my search? Thanks for any help or info you can provide. Peter Re: Rear brake calliper - devilsyam - 26-03-12 xjr fits Re: Rear brake calliper - solorider - 27-03-12 Have a look at item no 251026937111 on eBay ,can't post a link as I'm using my iPad Re: Rear brake calliper - kebab19 - 27-03-12 No others bar XJR with actual bluespot, but TRX850 & YZF750 rear calipers the same dimensions. Re: Rear brake calliper - greeny - 27-03-12 Thanks for the replys. I have brought the one off eBay. Thanks again Peter. |
